Daystar 2.5/1.5 lift problem. Front wheel hop in reverse.
charvey
2004 Sport 4x4 with xreas suspension. Just installed Daystar lift 2.5/1.5 and also installed new axles. Everthing works fine in foward gear, however reverse is another issue on front tires. When in reverse, cornering the front wheel hop is incredible at slow speed. Anybody have an idea if this is a axle issue, or a Daystar issue.
i would first go through and check the bolts on the spacer, make sure everything is tight
