daystar lift installed 06
Mark h20
I recently got the bug back, lifting vechicles ( oh what a feeling ) thanks to all of you and this site.I just finshed lifting my 06 t4r with the daystar kit 2.5 front / 2.0 back , purchased from wheelersoffroad great to deal with.Everything went very smoothly at my friends shop,around 1.5hrs for the front/rear kit installed and torqued, just waiting for the alignment shop to finish up. Alignment finished back to toyota spec ranges. Found tires 275/70/17 mounted them on the front, rubbing on fender liners like 285s.I am doing this without wheel spacers,would they really help out????. Going to run 265/70/17 nokian vatiiva a/t what a great tire. THANKS AGAIN
How do you like the 265/70/17's??? Do they rub at all?? Can you hit a few bumps with no worries??
Josh220, I see you have the same size tires.... what do you think?
Also... do either of you guys have any CV boot issues??
I use to have a 2000 tacoma4x4 with a 3"fabtech and 33/12.5's. I never had rubbing problems but I had a few issues with the boots.... I just don't wanna deal with that again on the T4R
kev
I haven't had any issues yet, I have only heard about the CV boots leaking with 3+ inches of lift. The 2/1 doesn't put too much strain on it. The tire size is great, I haven't had any rubbing except for occasionally when I back out of a driveway with the wheel turned all the way to the left. I think it's a combination of the wheel being turned, and being partially flexed.
Is that rub on the arm or the wheel well?
I haven't checked yet. I have to go out in a bit to check on all of the bolts and the sway bar to see what is rattling, so while i'm out there i'll see if I can tell. If not, i'll check the next time it happens.
Mark, congrats on the lift... now lets see some pics!
Good choice on tires, Vatiiva ( I will assume AT's based on the size) are a good year round choice for New England, especially the wet slop you get on the south shore. You can go bigger with a wheel spacer. Iron Clad Lou just added 1.25" spidertrax spacers, which allow even larger than 265's. Search for his recent post and pix. (although he runs 265/70 there are others running larger sizes) Some fender liner trimming is normal, but you really want to avoid rubbing the UCA's.
265/70/17's do not rub on my 4runner without a lift. However, it really is dependant on the type of tire. MT and agressive AT's have agressive treads near the sidewall and slight size variations between manufacturers all contirbute towards what rubs and what does not.
They don't touch the arm, but they rub the plastic in the wheel well slightly. I can see the tire tread marks on it. But like I said, it has only done it twice, and both times it was backing out of the same driveway with the wheels turned as far as possible to the left. They haven't rubbed when they are turned to the right from the same driveway yet. Odd.....
Thanks for checking it out. I think you have the closest setup to what mine will be. I've had my 08' on order since Dec.... they say delivery in March. I've been driving a beat up 00' Monte Carlo that the dealer hooked me up with..... so needless to say I'm anxious!!
Daystar lift 06
Hey KEV, I have had no rubbing on uca's' or on fender liners. I think what josh220 has posted is very possible. The nokians vatiiva AT in a 275/70/17 are 32.1 tall which did rub on fender liners,very close to the uca's and the 265/70/17 are 31.7 tall is what I am running. Away on business unable to post pics, will work on upon my return next week.
daystar lift 06
Hey ROOK, checkout my other post do wheelspacers really help. Adding w/s will allow the for wider tires (285/70/17) etc, so no contact is made at the uca's. They don't help in the diameter of the tire, you need to cut fenders and liners to fit larger than 275/70/17 in what I have exprienced. Had the nokians wr on 94 camry they made it like all wheel drive, logged 50k on them.Liked the vatiiva AT more aggresive than wr. How are the heated seats?
Daystar lift 06
march2008103.jpg~original
march2008104.jpg~original
march2008105.jpg~original
With lift installed with stock wheels & tires
kev
Many run that size on stock suspension with no issues . I've never had a rub with my 265/70/17's .
Mark h20 , Looks good , do you have weight in the back or is it nose high a little ????
Re: daystar lift 06
Mark h20 said:
With stock wheels and new nokian vatiiva ATs tires 265/70/17. Thanks josh220 for the photo info.
No problem at all. The lift looks great. How do you like it so far?
Kev, no rubbing so far over 400 miles, little offroading nothing.Yes the nose seems higher, but it is level on the running boards the bubble does no lie. Thanks
No prblems with lift re torqued all hardware.The ride is firmer not alot, the bigger tires smoothed it out.Very happy with lift,thanks again josh220
I was not indication that you were lying . Sometimes when parked on different angles it appears different.
