Daytime Running Lights
I haven't seen the wiring diagram for the 05 yet but it's most likely the same as the 03/04. You just need to swap out the flasher relay for the DRL variant. It's a purely plug and play exchange. The flasher is located behind the fuse panel on the driver's side dash.
Search the forums for a full discussion.
Relatively easy mod. The instructions can be found here or on yotatech. Simple plug and play.
In fact, while the factory DRL uses different bulbs, I can't tell the difference in brightness when you use the non-DRL bulbs.
Rick
Rialm
