Dead '98
FLEXincRunner
Well, i got the head swapped and the motor back together, but now it wont do ANYTHING. Got in to start it, all the lights in the dash came on blah blah, tried to start it and nothing. Thought it might be the battery but, with the headlights on they didn't dim neither did the gauge lights. However the clock and radio did dim???? and the brake light(in the dash) would flash when i tried to start it. Cleaned the starter and gave it a tap. It tried to turn over for a split second and stopped. Now all the gauge lights are out, along with the clock, radio, power outlet, heat/ac doesn't work or the door locks or power antenna. Headlights, taillights, and turn signals still work though. Starter relay clicks when i try to start it. Hooked the charger to it, put it on start, and still nothing. If i unhook the battery and reconnect it i get a clicking sound from under the dash for a few seconds then it stops. I even swapped the ecu to see what that would do and got nothing. Ideas?
Laredotx
