Dead Bug Question
imanabsolutezer
There is probably thread on this, and if so please direct me there, but until then what looks like a mosquito decided to lay itself to rest inside the console where all the gauges are, speedometer, tachometer, etc.
Is this a quick fix?
Thanks,
-W
yes take off the panel above your feet. Should be 4 10mm bolts.
Then unscrew the gauge cluster surround. Black frame.
Should be able to get to the 4 screws holding in the cluster assy.
Pull it out slowly and unplug the plugs.
Then easily push in the tabs around the cluster and pop off the face.
Shouldn't be too hard at all
