Dead Runner...Need Help
Trav
So I changed my oil and flushed my radiator, now my 95 runner wont start!!! After I filled my radiator and went to fire it up, it started and died right away. This happened 3 times so I tried disconnecting the battery, waiting a minute and reconnecting.
I tried to start it again and I got nothing. Just made a clicking and went dead. I played with the cables a little and my buzzer came on, cool. Tried to start, click click. So I put my battery on the charger and it was at 70%. I checked all the connections I could find and everything seems fine, no corrosion or anything loose. Keep in mind this thing ran perfect yesterday before I starting working on it.
A little back story on the rig:
I just bought this car a week ago and since then I have found a few odd things on it. First off the radio and dome lights didn't work so I checked the fuses and TA-DA! the fuse was missing. I also discovered an alarm on it but the owner didn't give me any remotes and I don't think its actually hooked up. in the little inline fuse holder for that was a prong connector instead of an actual fuse, so I put a fuse in that. Since I did those things everything has ran perfect up until now. I cant figure it out because I don't think I changed anything. The only other think I've done is remove the top of the airbox to check the filter....
Any help would be greatly appreciated!!!
I also took out the dome fuse and put the prong back in the "alarm" to see if that changed anything and it didn't
