Dealership Service: Never Trust, Always Verify
Quebec
On Wednesday February 14th I brought my 2013 4Runner Trail in for service at XXXXXX Toyota (XXX XXXX Parkway, XXXXXXX GA XXXXXX). My service advisor was JXXXXXXX XXXXXX.
With 35,992 miles on the odometer, I turned over my keys to my service advisor and waited in the lobby for my requested oil change to be completed. The wait was a bit longer than my experiences at other dealerships, but I was just grateful they could fit me into their schedule. Upon completion, I received my paperwork , my keys, and walked out to begin my inspection of the work. Though I didn’t ask for it, the technician had notated on the attached multi-point inspection: “38psi” (all around) for all tires.
Easy enough to confirm.
Note: Before departing that morning for the dealership I measured 32psi (all around - cold).
The tire pressure I measured upon being returned the vehicle the first time showed 34psi (all around-warm). Somehow I had lost 4psi on all tires in the 100 feet in the mechanics bay to the parking spot or someone had lied on that part of the inspection. No big deal, but why falsify that? Red flag one.
Next, I popped the hood and looked inside the engine bay. I found spilled pink coolant, just about everywhere on hoses but inside the coolant tank. In fact it was still on “L” for low. I couldn’t wrap my head around why someone would be going over the effort to try to fill coolant and get more where it doesn’t belong than it does. Red flag two.
Finally, I crawled under the vehicle, still parked in XXXXXX Toyota’s parking lot and visually inspected the skid plate and physically wiped my hand over its exposed side in an attempt to preemptively identify any errant oil which may have spilled in the process. Oil changes are messy, some messier than others. No spillage oil was found.
My service advisor having just left at this point, I returned to the bay where another stepped forward to assist me. After describing the descrepencies, he offered to bring the vehicle back into the bay to address them. I expressed to him my concern that if these small really miniscule items weren’t done correctly, how could I assume the other items were?
I handed him the keys, in the hope that possibly there was a miscommunication amongst the technicians, and that my vehicle had simply been the victim of a small mistake. After a short amount of time, my vehicle was brought back out, parked, I was apologized to and handed the keys. Once again, I measured the tires, popped the hood, and crawled under the vehicle. The tires now measured 41.5, 42, 40, 41psi. The coolant had been filled to the highest level, however spillage over the hoses remained. Again, under the vehicle, I wiped down the skid plate with a bare hands and found nothing. Nothing.
At this point, I was just willing to leave sadly concluding that service here was at worst messy and imprecise.
I drove home, parked the vehicle taking it out only once yesterday for a home depot run before my 2,500 mile cross country expedition to California.
This evening, when I began packing it for tomorrow’s scheduled departure, I noticed a huge oil spill underneath it. The skidplate, which the oil filter (not pan) sits below was soaking in oil. The same skid I had wiped barehanded at the dealership and found nothing. I popped the hood, pulled the dipstick and checked the level and found some oil on it, but was still concerned.
I had my girlfriend run me to HomeDepot in her car and grabbed a metric socket set (all my tools are at my destination). When we got back I crawled underneath my 4runner and attempted to remove the small oil drain cover which the technicians would had to have removed in order to reach the oil drain plug (two 12mm bolts). While one came off easily, the other spun freely without progress. Stripped. Red flag one.
So my next step was to remove the front plastic cover and skid plates (10mm and 12mm bolts) to try and see if maybe there was something else going on underneath the vehicle, which could’ve been the cause of such a leak.
Once removed it was easy to see that there was oil everywhere. In my opinion there shouldn’t be any overspray anywhere around here. By the time the oil filter cap comes off, most of the oil should have already drained from the engine and only a small amount remains to drain. There is oil everywhere in this area, not to mention all over the front skid plate (top and bottom). Red flag two.
After checking the surrounding area, I focused my attention directly on the oil filter housing. It looked as though dirty oil was at the very least dripping off the housing’s teeth from possibly being dropped in oil during it’s service. It wasn’t until I started wiping off the oil that I had realized what I was looking at. Teeth of the oil filter housing had been broken off. We’re past red flags at this point.
See it?
Of course not. How about from this angle?
My oil filter housing is leaking and it is fracturing along the side. Until it is removed, it must be assumed that it is cracked and is the source of the leak. This leak would have continued unnoticed until it eventually emptied itself and destroying the engine in the process.
This leak would have likely been unnoticed by me when I’m covering hundreds of miles per day and only stopping long enough to sleep at night. Let me also say that none of this would be noticeable by a customer at the dealership unless they had broken out their own tools to remove panels to inspect the work.
In summation, here is what I think happened:
Given that oil drain cover was unable to be removed by me tonight as a result of a stripped screw,
Given the excess amount of oil around the filter housing (all over the skid plate, frame, KDSS front sway bar,
Given the broken teeth on the filter housing and the fracture along its body,
Given the oil all over the ground,
I believe the technician tried to drain the oil from the oil filter housing, cracking it in the process of either removal or assembly.
Does anyone want to come to the defense of the dealer and find a flaw in my thoughts?
Thoughts on next steps? My cross country trip is obviously delayed until this is rectified.
Oil on KDSS Sway Bar
Oil on skid plate
Oil on cross member
wow this is my biggest fear. Sorry you have to go through this. I hope you're able to get some resolution. I fear they may just blame you for the damage as there is no way to prove the damage was done at the dealership now that it's off the lot.
Keep us updated. Best of luck!
Man I hate that for you. Glad you followed your gut and checked it. Imagine if you had just accepted the truck and hit the road?
This is why my 2015 has never seen the service dept. since new.
While I hate to actually type this this is the exact reason I do not let dealers touch my vehicles and do everything I possibly can myself. For stuff out of my league There is a local Indy who is great. I had a similar experience at a Jeep dealer with my previous grand Cherokee that was absolutely awful. Long story short the service manager called me a liar and it ended up getting taken to the GM of the dealer. Needless to say that SM is no longer there and I had lifetime oil changes at that dealer (never went back though).
I had a similar experience with my first service. Stripped or missing bolts
on the skid plate, and the filter was leaking.
I service it myself now.
I use the same tech each time whom I have know from back when he worked at the Lexus dealer next door when I had one. I text him my appt time and the service advisors and manager know how particular I am and only let him touch my vehicle and that includes driving it to and from the service dept to the shop. If I didn't have that ability I would service my own vehicle each time.
That is just unacceptable and shows how some dealers hire people who have no experience to make a quick profit off of a customer. Hopefully they can resolve the issue for you.
Unfortunately, your thoughts are likely correct.
Had a small puddle of oil in my garage after the first oil change at the dealer. Drain plug bolt was only on hand tight :madgrin:
That sucks. +1 on the reason why I work on my own vehicles and they never see the dealership. Oil change duties typically go to the least experienced techs. Good thing you caught it.
Seriously, there are full-time trolls here who spend all their time shi-ting in threads and defending guilty dealers. They will come up with inane ways to blame you so ignore them.
Start by contacting the General Manager of the dealership. Ask for an email so you can send them the photos.
There are some step by step escalation notes here:
http://www.tundraheadquarters.com/blog/toyota-customer-service-complaints-make-your-voice-heard/
1 - Calm down – if you get emotional, you’re more likely to be viewed as a “crazy person” rather than a person with a legitimate problem.
2 - Make a plan – Decide what you want the dealer or Toyota to do to solve your problem.
3 - Call the local dealership and ask to speak to the General Manager FIRST – do NOT call Toyota’s national hotline right away. Instead, gradually escalate from the local dealership to the regional office to the national hotline.
4 - Certified mail is legal correspondence, so use it if all else fails*
In my case I had to escalate to National and that got results. Keep us posted as best you can and good luck!
Even as busy as I am as a business owner I still to this day have never let anyone change oil in any of my vehicles. Bottom line is you cant trust any of them to do a good job. No one will treat your stuff like you would. Yes there are very very few exceptions to this rule but I have yet to see one.
Many dealerships use general service techs to perform basic PM jobs.
These are oil changes, tire rotations and fluid checks. In my experience these guys just came out of trade school or started an interest in auto repair.
Some to become excellent A or B techs but many just don't care.
This is why I do most of the schedule maintenance services myself or take my vehicle to a local shop.
Hopefully you can have this issue resolved without any push back from the dealer.
Good luck!
Have the Dealer fix the issue (It appears that they caused it). Then go out and find a good independent that services Toyota / Lexus in your neighborhood. With the exception of the airbag recall there is no reason to go to a dealership. Not even for the free oil change.
IMO
The tech that worked on your truck is a turd. Plain and simple. Not because he ****ed up, but because he didn't have the ****ing balls to own it and let his boss know that Toyota would need to cover some parts to make it right. Instead he sent the finished product out the door hoping it would never be noticed. This is a character flaw and it's just the tip of the ice burg of all things wrong with society. Folks seem to take more pride in how their social media accounts portray them rather than doing the right thing when no one is looking.
Bit of a rant I know, bummed to see you are dealing with this.
whether the damage occurred during removal or installation, that oil filter housing is way overtorqued. properly torqued, the metal clip on the plastic housing should be pretty much lined up with/a whisker beyond the raised hatch-mark on the metal sump.
this dealer is really burying the bar on substandard work. shameful.
I've had my 2010 4Runner with 50k to 3 different dealers and not happy with any of the repair service I've received. The main issue was a couple days after I got it it started smoking. The GMC dealer I got it from had to take it to toyota for "new valve guides". Not the problem. 2 months later I finally get it back with a new motor and this is how I got it back.
Grease on the headliner in 3 different spots.
Leaking coolant because they reused hose clamps
Multiple little things
Didn't tighten the ground bolt for the starter, left me stranded.
The most recent was at a different dealer for the airbag recall. I made an appointment over a month ahead of time. I took it in, dropped it off at 9am. Got a call at 4pm saying they didn't have any airbags and couldn't do the work.
They finally got them in and swapped it out and the first time I went to close my glove box it made a loud pop sound. Tried a few more time and it kept doing it. Called the dealer and they wanted me to drop it off for another day so they could look at it. Nope. I ended up finding my own fix.
I know there are good dealers out there but I've yet to find one close by.
AndiGarage
