Deck plate
Glockwarrior said:
What is it???
does anyone have pixs?
It is a plastic grommet with threaded cap for removal. You can buy one at a boating supply store. Basically it is a access cap used on boats. Mine was 10 bucks.
It's basically just a hole in the airbox but with the deckplate in place you can cap it if you are doing water crossings .
A bit more air adds a 7-8whp increase but it's not like you'd notice it but it's so cheap and easy to do it was worth $12.
Randompicsfor6-07054.jpg~original
When I did my deck plate I was not sure about the H.P. increase, however my motor seemed to have more spunk, and the throaty sound AA++
i dont know how many times we've been over this, but i think its time i go ahead and do it, can some one please as much as i hate to ask, post the link to the thread (or just explain) on how to do the deckplate mod.
Sure! 1: remove air box(where your air filter is 1 band 3 bolts). 2: cut hole. 3: Install deck plate (make sure step 2 is large enough). 4: reverse step 1 good luck!:D
It's also wise to seal the plate with a sensor safe sealer or make-a-gasket material and I added a screen to keep large debris off of the filter and collecting in the box.
Randompicsfor6-07053.jpg~original
Luceann
