Did not know what generation I had
SavedbyHim
We recently picket up a 95 4Runner Limited in beautiful shape. Years ago I owned 2 87's and loved them. Sure to wish I could have found one with a manual transmission as this one likes gas, a lot. Checked my first fill up and got just over 15 MPG. After filling up I added a can and a half of Seafoam as well as a can of their Trans Tune to the transmission.
The previous owner said he ran Castrol GTX which I think is fine but usually like full synthetic oils in my vehicles and motorcycles. The oil was changed just before I got it so unless I hear negative about synthetic use I will probably go that route.
I will have more posts with questions and hope to be able to be of some help but I am not very mechanically inclined. I do have a check engine light that comes on then goes off but now staying on longer. Will hopefully get it diagnosed at an auto parts store later but have a feeling it may have something to do with the gas cap as it creates quite a bit of vacuum making it very difficult to remove???
Thanks in advance for any help I may get. Need to start another thread about headlights.
The 95 if I'm not mistaken is obd-l. with engine off jump te1 and e1 on the little box next to the main fuse panel under the hood. paper clip or wire. turn key and check CEL. Should blink in some sort of sequence. (exp. 2 blinks slight pause and 4 blinks = code 24) it will pause between codes if more than one and repeat after it cycles through all codes.
