Diff breather mod
zerge916
I hear a lot about doing the rear diff breather mod to be able to safely drive through water. Is there anywhere else that needs a similar mod? Trans, front diff, etc. Have not been able to find much info.
Trans and diff are already re-routed. You should be able to find them on the drivers side of your engine, a couple of vent caps that look just like the one on your rear diff sticking straight up.
Like stared a above. Both front diff and trans case are routed to the driver side of the engine bay. The rear diff is the only one that need to be routed. My understanding is that when missing it can make it stay open and flood the diff. It's one of those better safe than sorry things but I don't think it's 100% a must.. depends on your wheeling style.
The ones you see on the driver side engine bay are the front diff. section only.
The trans and transfer case are above there components. If you get water to the floor board, you should raise them also. I did them yrs ago, not easy to get to them, but piece of mind.
So let me get this straight, we have 3 breathers that should be extended if going through deep water. Transmission, transfer case, and rear differential?
I was strictly focused on the dif breather... this knowledge changes things. Funny how so many threads only focus on the dif, wonder why that is? can anyone shed some light?
Front diff, trans, and transfer case breathers are already pretty high in the engine compartment. The rear diff however is going to suck water at the first deep puddle or stream crossing. Unless you treat your rig like a U-boat the rear diff is probably the one to worry about.
I just ordered the union so I'll be doing that mod once the part arrives. I'm planning a trip to an area near the Everglades soon so it's going to be a lot of water crossings. Better safe than sorry.
I have 2 lines on top of the trans in this picture.
Just feel above the trans where it meets the bell housing.
Transfer case, just feel on top of it. It is like a 1/4" hose with a tee going to, 2 different spots up there.
Sunday I can get under there and get pictures then to help you.
Ambrose67
