Differential Locker 02 4runner 2wd.
mapn2002
Can somebody help me, i need a differential locker and a 3" or 4" body lift for an '02 4runner 2wd sport edition, I have no idea what to get.
Why do you need it?? For looks or to improve off-roading capability?? Body lift?! Are you sure that you want to do this?? Are you planning on putting bigger tires?? Bigger tires do not agree with your 3.4L V6 engine...and then you will need to re-gear and that is a lot of $$.
Your '02 4runner already has traction control on the rear axle.
I need a differential locker
What kind of differential locker can I get for my 02 4runner 2wd, full time or not?
you dont want a full time locker for the rear
arb makes a locker for the rear but its around 700 bucks not including installation.
a 3"- 4" body lift? wow.... someone hasnt done any research....
um, dont get a bodylift... unless its like a 1" lift... a 3-4" body lift is going to look disgusting and may cause onlookers to vomit when they see your 3.4L below your body...
or when you hit a curb and your body keeps going but your frame and wheels will stop, if you want a lift, either stick with a 1" BL or actually drop some money and get a 2.5" suspension lift from OME. as for a selectable locker, i would recommend ARB, or OX. both are expensive, but there is a reason for that. detroit has some options that would work but i dont think they are fully selectable, but please, for toyota respect, do not get a 4" BL on it, remember, you drive a toyota, not a chevy
