Dipping Front & Rear Valence
Greedy
For those of you who have done it on a 14-15 trail, did you remove the valence or just mask and spray? Going to be doing them this weekend and want to get everything set. The front looks pretty accessible, but the rear looks like it would be difficult to get good coverage around the hitch. Thanks!
I had no issue just masking and painting. I just taped off the hitch really good and want at it. Just make sure you put a bunch of coats on, makes it easier to peal the excess. image.jpg
[MENTION=103040]nguyenn[/MENTION] - How did you handle painting the part of the flares that are molded into the bumpers? I was planning on doing a thick coat, and peeling the tape while it was still wet. Any other methods that you used that might work better?
I sprayed about 5-6 coats and peeled the tape when it was completely dried.
It is generally recommended to remove your tape immediately after your final coat. Once dried, pulling your tape cleanly is much more difficult, and can "tear" or cause rough edges. This is pretty common practice for anyone using dip. I would also recommend 3-4+ light coats of even coverage as opposed to heavy coats. Dip will run like paint if sprayed too thickly or if it is not shaken properly.
Practice Pictures 8-16 066.jpg by tConrad81, on Flickr
IMG_5044.jpg by tConrad81, on Flickr
Looks great! Is that Anthracite metallic on your valences? That is what I was planning on doing, along with black on the flares.
So if I spray 4 coats, allowing about 10 minutes between each coat, then take the tape off immediately after the last coat - it should come off cleanly? Won't the dried coats underneath the last one still want to grab the tape and peel? Or does the last coat re-soften the underlying coats and allow for a clean edge once the tape is removed? I have watched numerous videos online and am getting conflicting info. Thanks!
I would spray 5 coats. Thicker coverage is easier to remove if you need to. You are correct on removing the tape as soon as the final coat is on. The last coat will re-wet the previous coats. Good luck.
Thanks guys. Just sprayed a test patch on the back of a sheet pan, 5 good coats. Peeled the tape right after the last coat and it came off perfect. Time to start masking! Will post up pics after im all done..
AndiGarage
