Dirty Parts Dual Battery Kit
nytefog
Member
Hi,
Has one installed this dual kit in their T4R? I I'm just trying to make sure I mount the battery tray properly because the z bracket doesn't make contact on the one side and maybe I just need to put a spacer or some washers to make up the difference. The directions are all for the FJ so its not as clear when doing the install on the 4runner.
Also, do you guys keep the dual battery on all the time so that the battery is always charging? I know if you keep it off it won't charge which could be a problem if you go to use it in emergency mode and its dead.
Thanks for any info guys
utkrstam
