First thing, check to ensure your dome light door switches are working 100% of the time.
After that the door lock can be disabled in the lock system programming mode. You will probably need to spend more time searching this site for the necessary info than actually solving the problem, but it certainly can be done.
Check the FSM for instructions.
Interesting, I keep my dome light switch in the off position exactly for this reason, they work intermittantly. Not sure what they have to do with starting the car and the auto lock??
The PO installed an aftermarket alarm. wish I could just pull out the whole thing, but Im afraid Id screw something up. He also had 2 kill switches installed. In order to start the truck your seatbelt has to be on and you have to pull up on the passenger window control while turning the key! It drives me nuts. :crybaby:
Im not sure if the Owners Manual/FSM will be of any help?
It isn't an OE system, that's for sure...Lol, Im actually not sure whats locking my locks! But its really annoying.
The only time a 3rd gen will lock the doors by itself (in original form) is if you hit unlock on the remote, then don't operate a door for ~1 minute. This is only a problem if your driver's door switch is not working/unplugged.
If you have an aftermarket alarm, they will often be set to lock the doors when the key is turned to the 'ON' position.
-Charlie
