akaknowlesy
Hey all. I own an 05 Sport Edition 4WD and would like to disconnect the daytime running lights. Any advice on how to do it?
Daytime Running Lights - Page 4 - Toyota - 4Runner . org Forum:cheers:Hey all. I own an 05 Sport Edition 4WD and would like to disconnect the daytime running lights. Any advice on how to do it?
Disconnected mine at the stealership via a laptop computer. They charged $40. and I got to go with the mechanic while he did it b/c there are several options I had him turn off, like door locks: when you start your vehicle the door locks autmatically lock and then unlock when your vehicle is put in park or after you turn off the vehicle (cant remember which one it is/was). This feature is now turned off to save wear and tear on the actuators. Turning off the running lights is done with a click of a mouse. Worth the $40 to me.
Daytime Running Lights - Page 4 - Toyota - 4Runner . org ForumCool thanks guys! Question #2. Where would I find the DRL Relay?
Actuators like everything else need exercise. Why would you turn off the drl's anyways? You don't even see them on and can't notice a difference. Are you afraid of the upsetting the folks that are prone to having seizures in daytime driving?
Did you read the whole thing? 12 pages worth?![]()
Still wading thru it but getting some great info. Thanks.
When they disabled the DRL can you still turn them on manually? (by turning the light switch)
So where's the DRL relay? Did you find it yet?
Why can't you just remove the DRL fuse?![]()
From what I've been reading it has to be replaced with a non DRL relay.
