1engineer
Moderator
I thought having a manual transfer case like in the TRAIL, TRD PRO, or FJC was a bulletproof 4WD system compared to the push button/turn dial system in their other models? My previous Tacoma's all had the dial and often I'd hear it forcing itself in/out of 4WD. Sometimes beeping, sometimes chinking
Nate, not picking on you but I will use your post as an example!
"I thought" or "I assumed" is a common issue on many products and especially vehicles like the 4Runner.
The manual transfer case still needs solenoids to operate the ADD, or automatic disconnecting differential. So you do away with a dial and switch but still have solenoids downstream.
This is common on a lot of the operation of the 4Runner. What is also common is when people blame "Toyota" or this forum for their own ineptitude when it comes to researching operation procedures or features. How many posts have you read that people blame themselves for a problem?
Again, this thread highlights something that COULD happen and how to mitigate the potential issues that could arise from a CEL. That should be the takeaway here. Buy a code reader and learn how to use it.
To me, it's no different than losing an alternator or running down your battery or losing your keys. Any of these things happen its going to be a bad day out on the trail. The good news is you can carry a spare key, you can have a dual battery set up and now, if you leave your gas cap loose, you can tighten it, clear the codes and be back in business. Still, if your alternator craps out your are SOL up the creek with no paddle, unless you carry a spare, and who does that? My question still is how common is this problem? I have been reading threads for seven years and I only know of two instances of someone going into "limp mode" and they were not caused by a CEL or code issue. Maybe they happen and people don't post, but it seems every time anyone has a problem the first place they go is the internet to tell the world.
