DIY cheap and easy HID projector retrofit
Rapter
First and foremost you're attempting this at your own risk. I'm going to gather the info I used to do the retrofit on my own truck. I will try and be as detailed as possible and use as many pictures of the steps I have. Big thanks to SIGep4Runner(1st one to do use these projectors) and RitzyRunner(DIY headlight removal) over on YT. Hope you don't mind I'm going to use your pics and copy part of your DIY.
Things you will need:
Bi-xenon projector lens: Found on ebay from sellers in china for around $100. The kit consist of 2 projector lens, 2 HID bulbs and a harness for each projector.
HID Ballast: THE KIT DOES NOT COME WITH BALLAST. The seller where I bought mine sells ballast separately if you don't already have them. If it were me I would just buy a HID plug and play kit from DDM Tuning - HID Kits, DEPO Lights, BMW Bumpers & Lighting for $30-$50. The kits come with bulbs and ballast so for about the same amount of money you can have an extra set of bulbs as spares.
Tool:
Friend or an extra set of hand for a few minutes
Oven (Yes tell your wife her oven has now become our tool lol..)
Utility knife (IMO it was the most important tool)
Various screwdrivers (big head flat and a good phillips)
3/8 drive ratchet handle
6”-8” 3/8 drive extension
10mm deep socket
Needle nose pliers
#2 Philips screw driver
Oven mittens
Cook sheet or foil paper
Silicone (if your lucky this is optional)
Ok lets remove the headlights.....
'99 headlight Install on '98 - YotaTech Forums
Ok now that you have your headlights out you're half way there. Clean them off and go into your kitchen.
1. Preheat oven to 275 Temp. Remove upper grill/rack and leave one on the bottom.
2. You need to remove everything from the back of the headlight. There is a spring on there I didn't bother to take it off.
Everything on
DSCF2231.jpg~original
The black bracket is being held on by 3 clips and a spring. Unhook the spring and unclip the 3 clips. In order to remove clips you need to push in the two tabs on the clip simultaneously and pull the bracket. This is where you need the friend or an extra set of hands. Here is a pic of the clip. This is one of three clips the other two are have to be reached from the inside of bracket.
DSCF2232.jpg~original
Now everything off
DSCF2237.jpg~original
3. Once you have everything off it is now ready to go into the oven. Put it on a cookie sheet with some foil paper and put it in the oven for 7 mins.
DSCF2229.jpg~original
When 7 mins are up, take it out of the oven and place it somewhere where you can start to work on opening up the headlight. With your mitten or what ever you have to prevent from burning yourself hold the headlight, take the utility knife and make a couple of passes on the top of the headlight. For me, that barely broke the seal. Instead of making more passes I pressed down hard with the utility knife until I felt it break through the seal. I kept doing that every couple of inches until I had done the top and one side. By now the adhesive cooled off and I put it back in oven for 3 more minutes. Take it out of the oven and carefully try to separate the lens and backing with your screw driver. Be careful as I did chip one of my lens a bit because the seal wasn't open enough and I was trying to pry it open with the screwdriver. If that happens start off with knife until you have enough room to fit the screw driver in between the crevice
DSCF2241.jpg~original
4. Take your projector and slide it into the headlight. You will get instructions with your kit as to how to mount it. It's self explanatory and I didn't take pictures of this.
DSCF2234.jpg~original
5. Once you have it in there correctly(on the threaded part it will be marked top), held on nice and tight from the back with it's 3 prong spacer/aligner and nut you're ready to close it up. Press the lens and the backing together as much as possible. Put it back in the oven for 6 to 7 mins. Take it out and again immediately press it together again with your mittens until you feel you've sealed it up as much as possible. Here is where I say to apply a thin bead of silicone to ensure the seal is 100%.
DSCF2242-1.jpg~original
6 Do the same to the other headlight, put everything back on the back of the headlight and you're done with your retro job.
DSCF2244.jpg~original
Go back outside with the two supplied harness. One is longer than the other so make sure you use the right one for the right side. I personally didn't want the angel eyes so I decided to no hook that part up. You have a grnd, power with inline fuse that goes directly to the battery, two connectors that go the HID bulb, one that goes to the projector, one to the ballast and then small power and ground that belongs to the angel eyes(I cut the ends and taped them up).
7. Once you've hooked everything up tuck it away with a zip tie, double sided stick tape or just tuck it and hope it doesn't move around in there for you guys who off-road. Put your headlights and everything back on like it was before and congrats you're pretty much done.
8. Now you need to align your projector so they line up horizontally and your headlights so they line up vertically. Mine aren't aligned perfectly, but you get the point.
DSCF2248-1.jpg~original
DSCF2267.jpg~original
DSCF2275.jpg~original
Good write up man, very detailed and seems like you included everything. Ordered the ballasts last night so I should have both parts by week after next.
Can you check the supplied instructions and see how the angel eyes behave? I think it'd be awesome to have them come on with the corner lights. Would it be as simple as splicing it with the corner light wire?
Also, cutoff pictures as they're requesting would be ideal. Thanks man
Also, if you don't mind take a look at this. I'm using Bill's pictures as examples but would it be possible to put shrouds over them to complete the look? Thinking aboutt doing this.
cover3.jpg~original
cover4.jpg~original
CIMG1292.jpg~original
Great write up. Two things: 1) aligning the lights once reinstalled - is that done how you would do the OEM bulbs? Turning those little white tabs? 2) Any chance of getting some day time pics to see how they look in the grill?
Very nice mod. :cheers:
Also, if you don't mind take a look at this. I'm using Bill's pictures as examples but would it be possible to put shrouds over them to complete the look? Thinking aboutt doing this.]
Miller sorry man the shrouds are going to have a to be a trial and error type thing as I have no idea of the actual measurements of the projectors or the shrouds. For the AE's the instructions are very vague. All it says is power and ground. I'm sure you could wire it the way you want. You would just have to find out which wires are the ones go to the corner lamps.
Yes aligning the lights still works the same way as you would with stock lights. My friend didn't think I would need silicone so we put them back in without it. If you look at my left headlight you see a bit of condensation. I'm assuming it's because I didn't use silicone to make the seal 100%.
DSCF2252.jpg~original
I'm doing a retrofit with Murano projectors, where can I buy some shrouds? People say home depot but whats the part number?
Rapter awesome write up thanks for taking the time to do it. I am just finishing up paying for a set of these projector lenses and can't wait to get them installed.
You mentioned that you didn't want the halos - is the wiring there for them to work? Or do you have to pay extra for the halos? I'm on the fence as to whether or not I want them enabled when I install mine. The small rings just look a bit out of place in a large square housing.
ew no halos
ricer!:D
Need help finding projector that will fit.
Which projector did you use, Rapter? Are there actual 4runner projectors or can I use an OEM from a different vehicle? I drive a '98 4runner limited. I just need to know how to find projectors that will fit.
Thanks for the very detailed write up and pics.
He used bosch e46 projectors which are used on BMWs and different projectors can be used but they fit without alot of modifications to the housing. Just make sure watever projectors u get, they have bi-xenon so u can use lows and highs. These are sold all over ebay.
The best projectors are muranos, I'm in the process of installing some with the philips oem bulbs and 55 watt ballasts. :party::fro:
I believe Rapter used the G1 ebay projectors that are not found on any car from the factory they are made to be"plug and play" easier than a true retrofit.
Also some people think the Acura TL OEM projectors are the best they are like 03 to 08 or something around there
