DIY Gas Tank Skid
Jetboy
Thought I'd share a few quick pics of a project I did two weeks ago. It's been heavily tested since then... I'll get a trip report put together at some point. Still haven't unpacked yet. But the trip was rough enough to destroy a TRD Pro aluminum skid. They're just not strong enough for rock crawling unfortunately. Actually the steel OEM steel front skid is quite a bit better in terms of durability than the TRD Pro aluminum one.
A few build pics. My general philosophy is; less metal - more structure - lighter weight.
What would make this skid better would have been to rip 2" tube the long way and have rounded runners rather than using channel. But I was running out of time. In a perfect world I'd have an extra day to work on it and would have done it via a CNC cut single piece, but my day job got in the way and the trip was coming up fast so I just did it the old fashioned way - by tracing the tank with a sharpie and cutting the plate by hand with a plasma. The outer rim is 2" flat bar. It's easy to just start stitching it and bend as you go. The mounting brackets were actually pretty easy to fab. Again - would look prettier and probably be a bit lighter with formed plate, but I just didn't have time to design them.
The CNC design takes time I didn't have. I built the entire skid in about 5 hours, from driving in to driving out painted. I'd need at least a full day probably to do a CNC version. But then it'd be replicatable in maybe 1-2 hours for each additional one.
In a perfect world I'd have a stamp or roller to form thicker plate to be identical to the OEM skid, only with double the metal thickness. The oem design is better than anything any of us can actually build at home. It's just too thin for prime time. I tried by simply adding a plate to it. It survived the Rubicon last year, but it was pretty beat up.
So here's a few pics of how I did it. I use 1/4" flat spacers to add a small spacer for deflection during fitment. You don't want it actually touching the tank anywhere. Doing it this way fits very tightly, but not too close. Probably went on and off 15 times to get the mounting right. In a production shop You'd just buy a factory new skid and build a jig off of it. But my OEM skid was too far gone to really use as a template.
One other thought would be to use an OEM skid and add structure to it on the inside - 2mm of carbon fiber fabric and epoxy on the inside would probably make it stronger and lighter than any skid that exists otherwise. And it wouldn't be all that hard to do. If I had had a brand new OEM skid I might have tried that. And then add 2mm spacers to the mounting points.
Finally - it's a plastic tank. Please don't try to weld around it if you copy this design. Don't hurt yourself.
Love it. Kudos, man. Nice work. What's the weight of the final unit?
BTW - The thought of the reinforced fabric on the stock skid - dig it.
C
DIY gas tank skid
It looks good. It protects the sides of the tank more than most brands that are available. I have the RCI gas tank skid plate and that's what it doesn't do, protect the front of the tank from rocks flying off the front tires and other debris.
What thickness of material did you use? What does it weigh?
I didn't use a scale for a final weight. My guess by lifting it is about 40lb. There's roughly 6 square feet of 11ga - either 10 or 11, but I can't remember off the top of my head - just what I had in my rack. So the main plate weighs about 30lb. I'm guessing another 10lbs worth of mounting brackets and flat bar. The bottom side has two full length runners that are 1.5x.75 channel for structure. So the math on the materials suggests something like 40lbs total?
The biggest advantage is that it's still almost the same clearance as the OEM skid. Many aftermarket ones lose a few inches of clearance there. I turtled on it a dozen times probably and didn't have any issues with it bending like the reinforced OEM one I had last year. I really wish I had a large press brake to make corrugated 10ga. I think that would be ideal for most skids on these trucks.
I will probably pull it off again and add a full front rock shield like the OEM one has. Mine protects the edges pretty well - but the OEM covers the full front area.
The only other thing I may do is put two strips of UHMW plastic on the two reinforcing channel strips on the bottom. I'd lose another 1/2" of clearance, but slide a lot better. I just need to get some locally. I'll probably also add it to the transfer case skid. Those two places are where I get hung up on the most. Having some slippery plastic could go a long way to making a few obstacles easier to get through.
Also as a side note - this last trip I was on was with a 100 series land cruiser (on 35's, but relatively low lift height) and it has the OEM tank skid on it. - Land Cruiser OEM gas tank skids are much better than 4runner ones. Where the OEM 4runner is great for stones kicked up off the road - the LC100 is ready for dragging across rocks.
Double check your drive line / flange clearance to the skid when the rear drivers side is fully compressed and passenger side dropped.
This condition is when I found I was hitting the skid plate and ended up having to make modifications to get just enough clearance to no longer hit / rub.
Other than that, looks good!
No problems with driveline clearance. It fits tightly to the tank around that area. Something I was mindful of after reading about a few issues on here. I put it though it's paces last week. The Rubicon isn't the hardest trail out there - but the way it's setup does a pretty good job of finding any weaknesses you have. I also have KDSS and only about a 2 inch lift. So I'm not sure how much difference that makes in terms of limiting axle motion compared to an LT setup.
Awesome work!!
I have the time but not the tools these days, nice to see people building here instead of just buying and paying someone to install :clap2:
I just made this one for my 4th gen, CNC Plasma cut from 3/16 steel weighs 60lbs according to Solidworks, still need to trim some off here and there to get it to fit properly and will add 5/16 steel strips for vertical mounts. I basically copied the RCI design. Some UHMW strips on the bottom wouldn't be a bad idea, I crunched up my stock one pretty good from past wheeling.
Jhunt
