DIY tranny flush questions
wm69
Was nosing around under the 4runner yesterday and thought about swapping to synthetic and doing the DIY "flush" when I change over. I know there is a writeup on pulling a cooling line and running the old fluid into a bucket while periodically adding fluid and letting the tranny do the work.
I see two rubber lines going into the bottom of the radiator. I assume both of those are tranny lines. Which one did you pull off, and I guess you just run the hose into the bucket? Does anything come out of the rad fitting or would you have suction there? I guess if fluid is pouring out of the rubber line you would still have a bit of old fluid in the radiator line and the other line from radiator to transmission, right?
I think I'm going to switch to Mobil 1 after seeing more and more people who swear by the stuff. If I'm going to switch I think I'd want to get all of the old Dexron out of there. They're supposed to be compatible, but I'd rather get all syn in there.
1) There is no
DJNutshell
