do brake rotors need to be the same size?
really hoping this isn't as stupid a question as it feels:
I have a 2001 SR5 that I'm replacing the rotors and pads on. I ordered a pair of Brembo 43512 04020 rotors as replacements. I have the old rotors off and laid them on top of each other just to compare, but the new rotors are a little smaller in diameter. Is that normal/ok or did I buy the wrong part?
The center section is the same, just the diameter is a bit smaller.
these are the rotors in question:
2001 Toyota 4Runner Front Brake Disc 43512 04020
Any help would be appreciated. I'm on jack stands right now :)
How much smaller? A millimeter isn't gonna hurt anything. As long as the pads don't overhang the rotor, it's good. There are 2 brake systems on 3rd gens....the difference in rotor size is almost an inch. These are not interchangeable.
X2.... brakes are something you don't want to be sure about.
You probably got the ones for a 15" wheel, i accidentally did that too, return them and order the proper size ones. It's no good to have the overhang, you lose braking power.
That's what happened. Thanks for the replies. I had to pick a pair of OEM's up from the dealer in a pinch (at twice the price of the Brembos).
I'm going to put these here in case it helps the next googler not make the same mistake:
2001 Toyota 4Runner rotor sizes
15" Wheels: 43512 04020
16" Wheels: 43512 35210 (the more common size, I believe)
AlaskaRuss
