Here I go again! OK this is approx a 2 gal system, here is what you do: get 4 gallons of white vinegar and 6 gallons of distilled water. Do this:I'm going to change out the radiator, just to be safe against future strawberry milkshake. But I'm wondering, should I use any kind of chemical flush to clean out the rest of the system? If so, should I use the chemical stuff before or after the new radiator is installed? Also, what chemical to use? What about one of those flush/fill kits that you hook up to your hose, yay or nay?
1) Drain system completely
2) refill with white vinegar
3) run up to normal operating temp, run another 15-30 mins
4) allow system to cool completely
5) drain completely, allow system to cool
6) refill with distilled water
7) repeat step 3, then 4, then 5
Then, repeat steps 1-7 once again, and if you are still getting discharge, try one more time.
Once you are running clear, run another cycle of distilled water just to be sure, then drain completely. Top off with Toy red coolant, burp system properly, then check for leaks for the next few weeks. Costs half as much as a flush kit, works twice as good, and is all natural!
