Dobinsons 5th Gen T4R Suspension options - from Exit Offroad
Usually it does, but not all vehicles lean, and the ones that do don't always lean the same. Plus, you have KDSS which can cause a lean itself if it wasn't managed properly during the installation of the suspension.
Last question. How long do they take to settle fully?
Just wondering when I can redo my alignment and decide if I need to shim or not.
It's Christmas already! I finally ordered black 302/505 springs for the 2.5/1.5 lift setup. I'm going to pair this with my Bilsteins and a new set of 285 KO2s and the shiny 8.5" Ray10's in brushed copper sitting in my garage. The springs and new shoes should arrive next week. I also verified that I still have lifetime alignment with Firestone so that should save me some bucks on the install. I can't wait!!
A big thank you to Mike @Dobinsons!
Called it in and FedEx unlost my package. Shit is heavy as dick I guess I would have tried to loose it too.
Also spoke with Brian in Miami and tried unsuccessfully to get Dobisons USA to switch to UPS citing the documentary Castaway. I don't think he took me seriously.
It's going on this weekend. I'll leave my thoughts then.
Sent from my SM-G930T using Tapatalk
USPS lost a set of Fox 2.5 coilovers for me once. That was FUN. :snacker::bravo::closed_2:
So my current set up is TRD pro wheels with stock tires. I have Bilstien 5100 all around and max height on the front and a daystar spacer 1.5 in the rear. I’m also running spidertrax 1.25 spacers. If I want the same lift should I go with 302/505 springs for the 2.5/1.5? I don’t want to buy UCAs. But I would like to upgrade my tires later.
Yes, those would be the correct coils to use front and rear, as long as it's all stock weight.
Sorry for what I'm sure is a very common setup question, but I can't seem to locate the answer.
2015 non kdss and want to run 3" ish front and 2-2.5" rear. (If that makes for a good stance?)
Will have 285 K02s on 17x8, backspace of 4.1, offset -10 (countersteer type x)
Will have SPC UCAs.
Want to avoid BMC if at all possible. Okay with trimming and pushing liners.
Will likely add top rack (gobi or front runner 3/4) - No bumpers intended, no drawers.
Would this be the best kit setup below for a nice stance at the height desired?
FR coil = c59-302
FR shock = gs59-700
R coil = c59-325
R shock = gs59-705
w/ diff drop.
(do these require sway bar relocates?)
cheers!
Will have SPC UCAs.
FR coil = c59-302
FR shock = gs59-700
R coil = c59-325
R shock = gs59-705
w/ diff drop.
cheers!
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
Use the GS59-574 to get you that 3" to 3.25" up front.
No, sway bar links aren't required, although on the rear they would help put the sway bar back into a stock operating angle to help with articulation a little better.
This will be a good stance, lots of guys on here are running that 3" front and 2" rear setup.
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
[MENTION=109078]caskew13[/MENTION]....
I have the same setup except have 701 rear shock due to weight from 3rd row, sliders, etc. Been very happy with the setup.... ride and stance. You definitely will need your aftermarket UCA's.
Re-did the alignment today after a long off-roading trip. The technician got these numbers. Super pleased with the caster im getting from the UCAs.
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
Thanks so much. Any word on BMC with 285s at this lift? Is there a possibility it could settle into needing one after some time?
Awesome. I may go 701 as well considering the roof rack and possible sliders that I didnt consider until you mentioned it.
No regrets not having adjust-ability in the front?
I ordered a pair of c59-599 springs yesterday. Also a full set of bilsteins. Planning to go 1.75 setting on the billies up front and 599 rear springs with air lift bags in the back. Super stoked to try out these springs!
No regrets at all. No need as alignment came out great with UCA's, stance is good, ride is great. Also I am running 285's Wildpeaks and no BMC needed. Little close on the driver's side but OK. FWIW my wheels are are FN Pro's 17x8, 4.5" backspace, 0mm offset.
Very happy with the setup so far. Prob think about another alignment at some point this month.
Super Appreciate it. Going to order now!
People do a BMC if their wheels stick out too far, tires are too aggressive or if their alignment isn't balanced and forward enough away from the body mount. There are too many factors for anyone to tell you that you will or won't have to do a BMC. But if you do do a BMC, you won't have any clearance problems with it anymore!!
Hi Mike,
I'm liking the ride with the setup but I have a question.
I have:
SC59-001 Strut top plates 2
GS59-574B Gas Strut Black x 2
GS59-701B Gas Shock Black x 2
C59-302B Coil Springs Black x 2
C59-325B Coil Springs Black x 2
1/4" spacer passenger side front
I'm getting some left lean especially in the rear and a little less in the front.
What do I need to do to mitigate this?
Thanks,
Hi Mike. Just curious... read a post on here with someone adding about an additional 70 pounds and the c59-302 would get them at 2.25”...
I just ordered the MRR and want to stay around the 2.75” height I’m at now. was recommended the same cs59-302’s but my weight is a lot more. I’ll be adding the C4hybrid bumper (135lbs) and winch (about another 50lbs or so)... i know the MRR’s are adjustable so maybe that’s why I was recommended those springs then just adjust accordingly to final height?
Thanks.
Hi Mike,
I have:
Thanks,
The left side is lower? That's unusual on a vehicle with KDSS
Ambrose67
