From reading all the posts on the Eibach lift thread you dont need it as its supposed to work with the stock UCAs and still be able to get the alignment in spec. Thats for their 2.75/1 stage 1 lift.
[MENTION=148378]Crikeymike[/MENTION] I keep hearing that there is a heavier duty rear spring that is about to be released that is heavier than the 749V. Any truth to that?
Now a vehicle with KDSS really doesn't have body roll hardly at all, so that's something else to consider.
Yes.So, Mike. Would my KDSS with 705s be the best of both worlds? As far as comfort and minimal body roll. I drive an empty runner every day but will eventually be doing more highway time, and a once-a-year 20 hr road trip. I'll occasionally tow a small boat but I imagine I'll be getting AirLift for that.
did you get an alignment yet? did they get the castor in spec? If so I am thinking I can skip the aftermarket UCAs for now. I want the same set-up but was thinking 1.5 for the rear coils since I do want some rake. Also are the front and rear coils same length or you got the ones that are different driver side to passenger side to avoid the lean? I have KDSS and want to avoid the lean and not use spacers if not needed to get rid of it
I've got this similar setup coil wise but with KDSS. When I ordered Dobinsons had the 725's (325 rear coils with an extra 15mm built into the passenger side coil).
I don't see these listed anymore, would be worth asking [MENTION=148378]Crikeymike[/MENTION] if they stopped production on these? They perfectly leveled my truck out on the front and rear, no spacer up front.
The KDSS coils are still made, but almost never in stock, so I've redirected everything on my site and on here to sell the even height coils and add a spacer to anyone that has KDSS.Dobinsons site showed the front and rear springs with the KDSS option, 15mm extra for passenger side, I just need pick what height I want for the rear. Ill get the 2.5 springs for the front, but not sure if I want to do 2 in the rear or 1.5.
There are options for sure.I currently have a 2020 ORP. No KDSS. I still have stock tires and wheels on the vehicle but looking to upgrade the wheels soon. I’m also interested in a 2-3 inch lift with shocks and coils to be able to go off roading a bit more comfortable. the stock vehicle sits a bit too low for my liking. any suggestions? trying to keep it in the 500-800$ range. thanks!!!
The KDSS coils are also only made in teal, and everyone wants the variety to choose a color, which is only available in the even height coils.
Damn, right when I was about to pull the trigger on my lift. Mike, what kind of wait is there for those KDSS coils? I want the teal anyway. My shop says they usually get parts from you within a week. I would be willing to wait it out to do it right. Unsure if the spacer is really a big deal though.
