Does 5th gen suspension fit on 4th gen?
SoCalRunner
I have a 2004 4R with 170k miles. Original shocks are leaking and i was wondering if i could replace with some old 5th gen front and rear shocks.
TIA
TIA
From What I've read on here, yes, but not without some minor mod to the front shock. As I understand it, the 5th gen lower shock mounting bushing is just a little wider than the 4th gen, so you would have file, sand, machine, or otherwise narrow up the front lower shock bushing, and I don't think it's by much.
Lower front shock eyelet is a little wider. Nothing about 15 seconds on each face with an angle grinder and a flap wheel can’t fix.
Yes it does. I have front and rear from a 5th Gen TRD pro on mine. Front required basically no modification, think I had to maybe grind a small amount on the front shock eyelets as it was a tight fit. The upper mounts for the rear shocks were too small though and I had to take a step bit to them.
seltzernator
