Does a 96 have a cabin air filter?
whodkne
If not, how do we get a musty smell out of the AC? Is there some sort of cleaning method for the condensing unit?
i don't believe the 3rd gens have cabin filters. some methods of getting mildew smell out of ac duct:
1. wait until car is warmed up and while driving, turn the heat to highest it will go and turn fan on high. the heat will dry any condensation left in the airway.
2. with the car parked, turn fan on high using outside fresh air setting (not recycled air). stand outside and spray some lysol into where the air gets sucked into the cabin right below the windshield. (mechanic told me this trick)
3. make sure you use the outside fresh air setting every once in a while and not recirculate all the time.
Thanks, will try those out. I believe it was a smoker's car before and doesn't smell like it was ever opened up. I am shampooing and SUCKING all the water and gunk out of the carpets, put in several freshening scents and now want to clean out the AC. So I will start with your methods. Thanks!
also as a preventative measure, i always turn my ac off a mile or so before i reach my destination and turn up the fan with fresh air. this helps dry any water in the system before parking the car.
My '96 does not have a cabin filter. Turning off AC before parking is the best technique to prevent mildew smell.
If anyone's vehicle has a 'mildew' smell to it there is something WRONG.
No one should have to shut off the A/C a mile before to Prevent mildew - (though it is being nice the system to let it cool down some).
Figure out why your drain isn't draining completely and you'll get rid of the mildew smell. No different than a home A/C, you wouldn't put up with mildew smell! Even in super humid Houston, we don't get mildew from the humidity in A/C systems. :cowboy:
Mildew smell from excess moisture/humidity is pretty common in the south. Most new vehicles come with an afterblow option that turns the fan on for a few minutes after you turn the vehicle off to dry everything out.
No 3rd Gen has cabin filter. I'm with [MENTION=75316]jgue467[/MENTION] on this one something not right.
Bought 01 198k mi, Had smell drain working. PO traveled with dogs alot lot of hair everywhere.
Evap had layer of 16 yr dirt and hair that stayed damp. Once that was cleaned off things were better Lysol in duct work took care of the rest.
No, there is no cabin air filter. Parts stores sell an A/C duct deodorizer that you spray in through the cowl with the fan on high. Air conditioners remove moisture from the air so the ducts should not be damp inside after running for a while. Water condenses in the evaporator core and should drain out. Check you evaporator drain and check for mouse nests also.
While water does condense on the evaporator during operation the condenser does not shed all the water which is why there is an after blow option to dry the evaporator out.
charlesz
