Does Koyorad radiator (VH010665N) interfere with 4xInnovations front skid plate?
RidingDirty
Hey I was about to order the aluminum Koyorad radiator (VH010665N). It's the one that's mostly for people with manual transmissions because it can't be used as an ATF cooler, so you would need a separate ATF cooler. Anyway I was about to purchase the radiator because I have a manual transmission and I found this thread where this exact radiator has interference with someones RCI front skid plate. I don't need any more problems right now and already own 4xInnovations skids. Does anyone know if this radiator will interfere with my 4xInnovations front skid plate? Thank you.
Skids that work with Koyo Aluminum Radiator
Koyo Aluminum Radiator Toyota 4Runner (1996-2002) Manual Trans VH01066
– Redline360
– Redline360
you are talking about this skid?
1996-2002 4Runner Front Skid Plate
if the koyo is 2" shorter on the bottom like the stock manual trans rad then I would say probabaly not a problem as the koyo sits up between the frame rails and does not stick down at all.
I can't remember if anybody has installed it with the 4x innovations front skid, I have this front skid
3rd Gen 4Runner Skid Plates, 1996-2002
and it does not interfer with my radiator that is 2" longer, seems like a pretty safe bet.
Jhunt
