Doing a Tune-Up
Volley
Doing a Tune-Up of Sorts
Hey guys getting really to do some tune-up maintenance this weekend and trying to get my list together. So far I am doing:
Oil/filter change
Spark plugs/wires
Clean MAF and throttle body (May do deckplate mod while it's apart and if enough time)
Change front/rear diffs fluid
Change transfer case fluid
Grease drivetrain
That's all my wallet can afford right now due to the tires and timing belt getting done this week.
Later on will do:
Transmission fluid
Coolant flush
Power steering fluid
Brake fluid (probably not til I change brakes down the road)
Fuel Filter
Am I missing anything?
You got it pretty well covered. I would also inspect your serpentine belts. Look at your drums in the rear and make sure you don't have any leaky axle seals. Other than that, you probably have already made sure the timing belt and water pump were replaced at some point. If not, I would do those (or have them done for ~$6-700).
Oh yea I do have the O2 sensor already, I could throw that on. Shew gonna be a long (but fulfilling) Saturday!
A yes timing belt hasn't been done in 100k miles, water pump looks like never. Both with all belts/seals getting done on Wed. My wallet is saying enough already! :)
May i ask how you could tell the water pumps never been done?
Simply by the previous owner stating that he had never had it replaced and the records from the 1st owner show that the timing belt was replaced but nothing on the water pump.
I have a 98 with 246,000 miles.
Change the transmission fluid by opening up the drain plug and draining the pan. I do this every 10,000 miles. It is easy, it is cheap, and it is fast. I recommend doing it !
I also want to get a new 02 sensor but when I went to Autozone it asked for a front O2 and a rear O2. Should I get both replaced or is one more preferable than the other? I have 147,000 on mine. Thanks guys.
I'd just do the front one. The only function of the rear sensor is to throw the P0420 code if the cats are not doing their job. So if MIL is not on, no need to change rear sensor.
I'm still a newb. MIL?
Thank you! Anyone else's opinion?
Here you go with all you'll ever need lol
MIL is malfunction indicator light.
Acronyms and Definitions for FAQ
Common Forum Lingo:
AFAIK - As far as I know
BTW - By the way
FWIW - For What it's worth
FYI - For your information
IIRC- If I recall correctly
IMHO - In my humble opinion
IMO - In my opinion
LMAO - Laughing my @$$ off
LOL - Laugh out loud
OTOH - On the other hand
ROTFLOL - Rolling on the floor laughing out loud
ROTFLMAO - Rolling on the floor laughing my ass off
RTFM - Read the F-ing Manual
YMMV - Your methods/mileage may vary
Technical Acronyms:
ABS - Acronym for Anti-lock Braking System. This system uses a computer to control your brakes on your car by applying and releasing your brakes quickly to prevent skidding or sliding from occuring.
ALT - Alternator: power generator for automobiles
ARB - australian 4x4 accessories manufacturer
AT - Automatic Transmission
AT - (tires) All Terrain
ATF - Automatic Transmission fluid
CEL - check engine light, sometimes refers tocode that cuased light that can be read by a code reader
CDL Switch- Center Differential Lock Switch- Switch installed to allow the Center Differential to be locked when the transfer case is in High. The actual Center Differential Lock is in the Transfer Case.
DS- Driver's side
DS: Drive Shaft=shafts that carry power and torque from the engine/tranny/xfer case to the axles.
DC DS=Double Cardan Drive Shaft=a pair of joints in a drive shaft that allows the tube to move in various directions and angularities.
Diffs - Differentials: found in the front and rear axles that consists of gears that transmit equal power and torque even if they rotate at different speeds.
ECT - Electronically Controlled Transmission - allows the engine to rev to a higher rpm before shifting to the next gear. Basically changes the shift points for the transmission. (Best for towing or heavier loads)
EGR = Exhaust Gas Recirculation valve
EWD or WD - Electrical Wiring Diagram, (part of FSM set)
FAQ - Frequently Asked Questions
FHH = Firewall Heater Hose
FSM - Factory Service Manual. The "bible" as published by the manufacturer. Used to guide in repairs
HG - Head Gasket
IAC = Idle Air Control solenoid
JDM- Japan Domestic Market- Refers to items particular to vehicles manufactured and sold in the Japanese market.
Items include but are not limited to:
Power retracting mirrors
Dual air conditioning
Adjustible shocks
Winches
and various cool and some gawdy accessories.
LB/FT - pound feet of torque
LB/IN - pound inches of torque
LHD (Left-Hand Drive): steering wheel on the left side, driving on the right side of the road
LSPV - Load Sensing Proportioning Valve
MAF - Mass air flow sensor
MIL - Malfunction Indicator Light (same as a CEL)
M&S - (tires) Mud and Snow
MT - Manual Transmission
MT - (tires) Mud Terrain
NA - Naturally Aspirated - An engine that is not turbocharged nor supercharged
OBDII - On Board Diagnostics Port available on ALL cars sold in the US 199 and later. Allows a common intercface tool to be connected to read and reset engine fault codes (CEL). Many Autpart stores will read your code for free vs. paying the dealer.
OEM - Original Equipment Manufacturer. (Toyota in this case)
OME - Old Man Emu. An Australian four wheel drive specialty manufacturer that makes all kinds of cool stuff that causes us to empty our billfolds.
PCV Valve - The Positive Crankcase Ventilation valve is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned.
PI - Propane Injection - Propane is injected into the intake as a diesel catalyst for a more complete burn and additional power
PM - preventive mantenance
PM - private message
PO - Previous owner
POS - Piece of S#1T
PS- Passenger side
PSI - Pounds per square inch - A measure,emt of pressure.
RHD (Right-Hand Drive): steering wheel on the right side, driving on the left side of the road.
RPM - Rotations Per Minute
SAS- Solid Axle Swap
SOA - Sprong Over Axle - A suspension lift for a leaf (Vs 80 series coil) spring suspension. It places the leaf springs on top of the axle vs the bottom.
SC or S/C = Supercharger/Supercharged
SSM - Special Service Materials
SST - Special Service Tools
SUA = Spring under axle. Stock configuration for a Leaf Spring Vehicle (vs. SOA previously mentioned).
TB - Throttle Body: controls air flow into engine system in response to gas pedal depression.
TC or T/C = Turbocharger/Turbocharged
TLCA - Toyota Land Cruiser Association (tlca.org) - The Toyota Land Cruiser Association (TLCA) is a 4 wheel drive organization open to all Toyota 4 wheel drive vehicles (except sedan types). This includes all models of Land Cruisers, 4Runners, and 4x4 trucks.
TPS = Throttle Position Sensor, may also be the "kick down" cable
USDS- US driver's side or the left-hand side of the vehicle.
USPS - US passenger side or the right-hand side of the vehicle.
VSV - Vacuum Switching Valve. An electrically controlled valve that diverts vacuum according to the position of the switch.
xfer=Transfer case: sits behind transmission, has front and rear drive shafts coming out of it, and distributes power from the transmission to the front and rear differentials/axles.
I would add:
-Check/replace (if needed) struts/shocks
-Check/replace brakes and brake lines (1997 Limited 4Runner's brake lines were near failure and my trusty mechanic Bob tipped me off to their needing replacement ASAP)
-Check/replace valve cover gaskets, spark plug gaskets, intake plenum gaskets, TB gaskets (TB cleaning), PCV valve grommet, etc
-Check/replace all drive belts
-Check/replace timing belt, water pump, etc
-Check/replace bulbs
-Check/replace ball joints, tie rod ends, steering components, sway bar bushings, etc.
-Check/replace starter (I had a Denso reman installed to replace factory starter at 175,000 miles. I considered just repairing starter solenoids but for $200 parts and labor I'd rather have peace of mind when we start or 4Runner especially living in north WI. And now it just sounds SO much better when starting, like a Lexus haha.), alternator
-Check for rust on undercarriage, bumpers, body panels, frame and if you live in or near Canada I would highly recommend Krown or Rust Check in the US.
Other than that, long live the 4Runner!
Thermostat = cheap insurance
also
Belts
Hoses
PCV valve
Didn't get everything done, ran out of time. Got a quick question though. Plan on doing a seafoam treatment, should I do this before or after changing out everything (PCV, fuel filter, O2, ect.). Also getting all the belts, timing, water pump, t-stat and seals replaced in a couple days. Will it matter if I did this before or after seafoam?
Thanks!
Oil/Filter, timing belt, WP, T-stat, all belts and seals, spark plugs/wires, drivetrain greased, MAF, throttle body cleaned all done! Shew!
Doing front/read diff fluids, transfer case, O2 sensor, PCV, deckplate mod :D this weekend!
Will do the coolant, trans drain and fill, fuel filter, steering rack guide and bushings upon my return from a much needed trip.
She's coming along nicely!
Maintenance didn't go as planned. Spent all morning on a wild goose chase for the right parts. By the time I got started, couldn't get the slightly rounded fill plug of the diff off. By that time I was tired and frustrated so called it a day.
Did manage to get the PCV valve replaced and installed the intake tube from my free K&N kit to the factory airbox. Just waiting for my deckplate parts!
