Dome circuit Electrical Problem
bmackey
Here's a real beaut of an electrical problem on our 2004 V8 2WD 4Runner which is used as a tow vehicle for my racecar. The car was still under extended warranty and this jewel took the dealer MANY hours of diagnostic time:
Problem: Intermittent blown 10-amp fuse on the "Dome" circuit. This circuit includes dome lights, door remote, guage "memory", clock memory, and other low-amp stuff.
Fuse kept blowing for no apparent reason. First pass through the dealer resulted in their replacing 2 body computers which ran about $800. The dealer proclaimed the problem fixed, and we went on our merry way. About a month later, same deal. Fuse blown. Back to the dealer again. This time they kept the car for almost a week.
Several tech's tried to diagnose the problem and they were about ready to give up, when one of the other techs overheard the conversation and promptly offered the solution: He calmly opened the driver's door and flipped down the sun visor. BANG! the fuse blew.
Seems this is a problem not only with the 4Runner, but also in some Camry's and Sequoias. The visors have a wire inside that is subject to abrasion against the metal rod that runs through the visor.
Solution: Dealer changed out the visor and malady disappears!
Just in case you run into the same problem, check the Visor! Whoda thunk it!!
Encountered this same problem.
Fortunately, it happened once while the truck was still under warranty. They replaced the fuse.
A couple of months later it happened again - only this time fuse would blow instantly when replaced.
It took them about a week to figure it out.
Once they replaced the visor, it's been fine ever since.
Lou
