I cannot unlock all doors using the lock button on the driver side or passenger side and also by using the remore entry key. I can lock all doors by using the lock button on the driver side.
I can use the remote or the door switch to unlock and lock all doors, BUT the driver side. I have to do it manually. I'm curious to see the experts answer here too!
Your problem is the door lock solenoid or wiring to it. I have a door lock actuator if it is your problem- $20 shipped
To elaborate, the lock works about 3% of the time with the switch or remote. Do you have the part I need to fix?
I have a similar problem, All my doors lock fine by the remote or the drivers side button, but unlocking the driver door I have to pull on the exterior door handle first before it will unlock, with both the remote and the drivers door button. Kinda annoying when I lock myself in, have to roll my window down to pull my door handle before I can even pull the lock up.
Singtoe, the actuator you have, is it passenger or drivers side? For what Gen?
