Double Decker Cargo Part Swap.
Az4runnin
Senior Member
Anyone in the Phoenix area interested in doing a Swap of parts? Wanna get Rid of the Double Decker Cargo divider. 2003 Limited. Color is Taupe (Tan).
Anyone in the Phoenix area interested in doing a Swap of parts? Wanna get Rid of the Double Decker Cargo divider. 2003 Limited. Color is Stone(Tan).
You do know you need to drill out spot welds from the donor vehicle and then rivet the latches into place in the new vehicle?
I added this to my SR5 and it was not hard, but it did require a little work and a little engineering
No Did Not Know that...any pics or other info(tips) would be appreciated. Thanks for letting me know. Just really don't use it much and thought someone could get more use out of it than I would.
I do not have pics, but it has not been that long since I did it.
There are two raised tin brackets welded to the floor with 1/4 spot welds. It is the latches where the deck locks in. All you have to do is drill out the 4 spot welds with a 1/4 but and they fall off. If you delet the deck, you will want to remove these anyway. Then plug the holes.
Whoever wants the double decker will need to swap you carpet and filler piece behind the seat and the two corner pockets.
In short. You need to trade, the deck, the carpet, the pad, the brackets, the two corner pockets, and the back seat filler, for a non double decker carpet, pad, and filler piece behind the seat.
For what it's worth, it's an easy swap, but it's best to find someone near you, so you can swap the parts you need. All you need for the swap, is a 1/4 drill but, 4x rivets, a Philips screwdriver and a 10mm wrench. I did mine in about 45 min the first time and when I switched it back to the limited, it took about 30.
Thanks TOY2G. I appreciate all that info. If I can't find someone to trade I may just buy the pieces I need and maybe sell the stuff locally. I'm sure someone would want it...
utkrstam
