driveline clunk and noise issues, something new
bassmacka
Member
Im used the to the driveline clunk. When I release the brake to start moving I can feel the clunk. It used to happen sometimes. Now it happens all the time but recently it changed and is more of a click and clunk. Also some purring sounds and vibration when the brake is applied before I accelerate and also I get the tick/click noise when I slow to a stop. Does it need some service? What to look for and check?
Seems like the clunk was related to drive line zerks needing grease.
The brake thing could be warped rotor, sticky caliper, bad wheel bearing, maybe a rock in there, check return spring (on caliper/pads).
Lift the tires off the ground and spin them...listen for noise.
Pull the front wheels off and inspect the brakes. Spin hubs by hand, listen for noise.
