Driver side brake light no workie
look171
Searched, but found out their have own 15 amp fuse for each brake light. So I go and look and there's none under the driver side panel. Only a 10 amp tail light fuse. If that one fuse controls both tail lights, then both would not work. My next question is, how the heck do you open the fuse box in under the trunk?
Do you mean under the hood? If so,on the cover the single clip (closest to the firewall side),push the top of the clip in and lift up at the same time. You don't need much force at all. Pretty simple.
One of my brake lights stopped working after a rough offroad trip one time. I changed the bulb and it still didn't work. It ended up being the connector going into the brake light. A little nudge and wiggle on the wire harness and it's worked ever since. Remove the access panel next too the rear hatch on the inside. First remove the bulb and make sure the filament isn't burned out. Replace the bulb, and wiggle the wires around going to the bulb, while someone else is pressing the brake. I'm sure you'll figure it out. Doesn't sound like a fuse problem.
Oh, my truck is a 2010 limited 4wd
Hi look171,
The fuse that you want is the Tail fuse 10A located in the driverside fusebox (near the E-brake). But as you've said... if that fuse were blown, you'd have no brake or side marker lights. Check the bulb itself by removing it from it's socket and look for a broken filament. If that's good, look for evidence of water (condensation) stains or rust on the contacts. If it's wet or dirty, clean it good with WD-40; which will displace any moisture on and around the socket, and then reinstall it. Let us know how you make out. If that's not the problem, we'll check it further for trouble in the circuit.
**Oh btw, to open the Relay/fusebox under the hood, there's a latch (or two) on the frontside that you'll push in while lifting at the same time... it'll come right off.
Cheers!
Thanks for the tips gents. The fuse box kicked my ass tonight. I couldn't get it off and felt like a big dumb ass:bash: First thing I did was a new bulb, so now I must move the wires around some. No moisture in there. We don't have any rain in Socal. Report back tomorrow.
Thank you folks. I jiggled the three wires around in there and it worked like charm.
Jeff
Hi Jeff,
glad you were able to isolate the trouble! Just a suggestion... you may wanna check that light socket and wiring in the chase; if jiggling those wires cause the light to go on/off intermittently, there's a bad connection in that harness... a proper electrical circuit should never behave that way, ...just my 0.000002 cents. Best!
Hi Jeff,
I only jiggled the connection to the socket. I think the crimping is not all the way in or loose somehow.
I have the same truck as you and had the same problem. When jiggling the light stopped working, I pulled the tail light housing off and cleaned the contacts for the brake light, and it is working now like a charm.
Yeah something is causing an intermittent loss of electrical source; could be a dirty light socket as in [MENTION=52568]rjfowler[/MENTION]s case. If that's the cause, I'd clean out the socket and treat it with WD-40 to displace any moisture and prevent corrosion.
Thanks for the tip. Will do.
Just for future reference...
The L & R 'Stop lights', 'tail-lights' and 'side-marker lights' are all on the same fuse labeled: Tail 10A ...glad you got it working again!
Cheers
- sovled -
Same issue 2011 Limited
Driver's side brake light, everything else work. Replaced the bulb, still not working. Reinserted connector and lower bulb. Works fine now.
THANK YOU!
10-13 taillight design (wiring) is pretty kooky and obviously prone to this failure. had an issue with mine about a year ago so i cleaned and straightened all contacts which managed to set it right for a while, however, started getting intermittent issues on stop lamp circuit again some time later. chased it for a while before giving up and upgrading to 14+ tails. such a better design; no regrets.
