driver side high beam doesnt work
haigaz
driver side high beam doesnt work. low beams and fogs are just fine. I changed the bulb and still nothing...Can anyone help? is there a fuse?
Open your hood. Directly behind the battery is a fusebox. Take off the cover and look underneath. Upper right hand corner you will see it marked as "H/L L/S HI . It's a 10 amp mini fuse. That should be your problem! :)
Antman to the rescue again! Good job bud.
Im having this same trouble. High beams not working...Changed out with SilverlightUltra's, still no high beam. Checked the fuses and they are good. Still no high beam. I guess I will change them even though they look good. Maybe the tips are bad. Never heard of that but its a cheap check.
Any other advice if this doesn't work?
Antman, where are you?
Is it one HB or both?
Were they bad before you swapped, or after, or both?
HB only. I can flash them just fine but when I try to put the HB on they dont work. I'm now thinking its a switch. Rockauto.com and autopartswarehouse.com dont have the one i need and its $115 @ Autozone. Im looking for one with fog light and light control system.
Any other websites out there where you can find this?
[UPDATE]
I hit a pothole in the road on my way to CO and it started working. Yay for potholes!!!
