Driver Side Lean
2023 Driver side Lean with 2in front spacers
I installed Icons 2 in front spacers on my 2023 SR5 from Yota Expeditions. My front measures exactly on both sides within a couple millimeters. The passenger back from the floor to the fender is 37 inches and the drivers side is 36.6 inches. Yota recommended this 10mm spacer for the drivers rear - Rear Trim Spacer For Driver Side Lean
At different angles the 4 runner looks level on both sides depending on where it is parked and at times both sides appear to have a reverse rake depending on where it is parked. The drivers rears does measure lower though. I was wondering if installing a rear spacer on both sides in the back might be the best route. Of course the drivers side would be lower still but my thinking is since you can't see both sides at the same time both sides might have a more level look or a very slight forward rake which would be ideal. I'd hate to install the drivers side rear alone and end up having it make the front side measuremens off. Not sure if that is possible with a 2023 5th gen compared to older gens.
Has anyone done both spacers before? Any thoughts? Thanks.
DJNutshell
