Drivers door lock.....again
Lamer
I started a thread a while back to try and solve my driver's door unlock issue. All the suggestions were executed, and unfortunately the problem still exists.......HOWEVER! there is a new symptom/sign which may help get a better idea of the problem.
to refresh: You can only unlock the driver's door from the outside when turning the key. (I should be able to unlock the entire car) (My passenger door unlocks all doors without issue.)
new symptom: today, I was in a rush and unlocked my door jumped in and closed the door quickly behind me (like trying to get in a car while its raining). when the door shut, every other door unlocked.
I was able to repeat this event. and determined it only works if you close the newly unlocked driver's door within about 3 seconds of unlocking it.
does anyone have any ideas?
Facts
  • I checked the interior electric lock/unlock switch inside - no loose wires or connections, and that works just fine.
  • I checked all of the linkages within the door and couldn't find any that were loose/damaged (kinda want to do this again to be sure)
  • The key unlocks the drivers door without issue, on the first try every time.
  • all doors open when the drivers door is closed shorty after it is unlocked
  • I really tired of this being a problem
044runner4
