Drivers Door Locking Actuator
madeinhb
I have a 2006 SR5. All my other doors work perfect. Drivers Door has been acting up. Took door pane off and the lock switch was detached from the cable. I put that back together and reassembled the panel. The lock worked manually but the remote is hit or miss. Sometimes it locks and sometimes it doesn't. When using the remote - it's like the actuator doesn't push/pull the cable enough to engage/disengage the lock.
Is there an easy fix or does the whole actuator need to be replaced? I have already removed the actuator from the door.
charlesz
