Dropping the Front IFS
Quatre Coureur
Dropping the IFS
So I'm swapping my ifs with a 4.88 one I got out of the junkyard. My problem is I can't seem to drop it out without the axle studs getting hung up on the CVs. I tried searching but it was all about pulling the cvs. Mine are good, I just don't want to trash them if I don't have to. It's my first time doing this. I've followed the FSM. It says unbolt the 6 bolts holding the CVs, then unbolt the 3 bolts holding the diff in. It should pop right out. Right!!! These Fn studs are pissing me off! I've pulled back the CVs as far as they'll go. Am I missing something? :boom:
Use a long bar or pipe and pound the studs out. They are just splined and should pop right out.
Yes, drive the studs out. Then grind off the splines or replace them with grade 8 bolts so you don't have to do it again when you break a CV on the trail.
They should, but I know from experience, that is not always the case. The ones in the Minnow were insane. Glad I replaced them with bolts.
I couldn't pound them out from under the truck either. I had to disconnect the upper ball joint on one side and move the spindle outboard to make the CV clear the studs. I pounded them out after I removed the halfaxles.
I've seen guys claim to not have to pound studs or remove balljoints. I think anybody that manages to drop a CV that easy has a pact with the devil or something.
When I switched to 4.88s I took a grinder to the studs and they worked perfect when I reinstalled them
Thank u Hyde, KV, FOG, and 88yota. I really appreciate the advice. It will make it so much easier to reinstall too. I was wondering how in the hell I was gonna simultaneously line up 12 bolts while raising it up...:doh: Again, thank u all sooo much!
