Dual Outlet Ash Tray
mrpanic7
does anyone have any links where we can purchase the dual outlet ash tray? I had found a few links on some older threads but no longer work. Thanks
It's nice to have a stock part though, way cleaner :roadkill:
IMAG1280.jpg~original
part #: 74110-35010-B0
A guy on ebay wants $69 + 8 on shipping. Partznet has it for $61.82 (shipping varies)
what kind of wiring needs to be done to hook this up into the console?
From what I understand, it's plug and play. If you tear your center console apart, you will notice a plug that isn't used. This is where you plug her in.
Someone correct me if I'm wrong. I may pull the trigger (I'm not a smoker, in fact I have asthma, but I sometimes find myself looking for another plug on trips. It's OEM and its expensive, worth it IMO).
Completely plug and play, there's an extra larger plug that's not hooked to anything. I just unplugged the old, snapped in the new, switched the old plug for the larger one that wasn't in use, and *poof* I now have 2 x 12V outlets :guitar3:
I am not a smoker either, in fact I removed the cig lighter as soon as the part came in. Just nice to have dual outlets
12v outlet
Easiest mod there is !! Not a smoker either but great ph. charger & or garmin, cobra, plus its factory so clean .
You are correct, there's an unused connector that you just plug in to the new unit along with the connector that was being used on the old single unit. So there are two connectors but they'll both be there to easily plug in.
Does anyone who did this mod have their original part? The bottom just broke out of mine and all my change is inside the center console. I don't really want the dual outlet part just the original. hoping someone still has theirs.
Maybe someone who has already installed the cig lighter option can verify this, but I suspect that unlike the 12vdc accessory outlet the cig lighter socket is powered on all the time. If I am right, then leaving an accessory plugged into it overnight might create a battery draw that could cause a less than perfect battery to fail. Something to think about.
Incorrect. It operates on the accessory like the other 12V outlet does.
CoaterZ_FL
