Another thing you might look into is having the air cycle on recirculate so it's not bringing in the dust and outside air.
Yes. I have the same problem. I've a sr5. I drive on atacama desert in Chile. Windows closed and air recirculate on max. LOTS of dust inside.Have a 5th Gen Limited. I live on gravel roads. The inside of my car is coated in dust. The windows and sunroof are closed when I drive on my road. Has anyone else had this problem? I think it is coming in through the hatch.
It's a button - it can be ON or OFF....recirculate on max.
anyway, recirc off, fan on. This pressurizes the cabin and works much better than recirc on.
Recirc OFF, fan ON. This pressurizes the cabin and works much better than Recirc ON.
The owners manual states exactly that. It states that if you are driving on a dusty road, turn recirc off and the fan on.
JB, if you turn off Recirc, doesn't the HVAC system then default to the "dusty outside air"? If true, pushing the outside air in may in fact add a bit of pressure inside the cabin, and that air will go through the filter. But if it is that dusty, the cabin filter will only trap so much, and it will clog the filter very quickly.
One can assume then that "Recirc" still allows some outside air in, right? This would seem to be different then other vehicles I have owned, or maybe not!
