Dynomax VT exhaust muffler on 2004 V8
WXman
I wanted a muffler that would provide better flow, take up less space under the vehicle, and sound great...but with NO interior noise or drone.
In the past, I've run Flowmaster 40 and 50 series mufflers, Thrush, Powerflo, Magnaflow, straight pipes, etc. Pretty much every brand and configuration out there, I've run it on my 4x4s in the past. With most of the ones I've had, there was a good sound outside the vehicle but there was a lot of DRONE and noise inside the cab of the truck around 1,600 RPM. Drone will drive you crazy and it's especially annoying to the wife and kids. So I did NOT want that.
I searched and searched the threads on this forum, and Google and everybody has varying opinions on the Magnaflow and Flowmaster setups. I couldn't really get a good feeling for what to expect. Then I stumbled upon the Dynomax website and noticed that they have a new muffler called the VT which stands for Valve Technology. The principle is simple...while cruising, an internal valve closes and prevents drone and reverberation inside the vehicle. When accelerating, the valve opens and allows straight through flow and performance. The valve is spring loaded and works off the airflow, no electric solenoids needed.
I ordered up part # 17949 from Summit Racing and it was delivered 48 hours later for $90 bucks. I took it to a reputable exhaust shop 30 miles away and they installed it this morning.
O M G. :jaw drop:
This muffler is the most awesome one I've ever used. At idle it literally sounds like the factory muffler. Cruising at 55, 60, 70...doesn't matter. There is NO drone. All you can hear inside is a mellow, sightly louder tone than factory. If you stomp it...it wakes up. The i-force V8 comes to life and this thing will scream. I freaking LOVE this muffler. Thank you Dynomax for making a muffler that doesn't run you out of the cab!
My previous experience with mufflers of this type (fiberglass packing inside) is that they will get louder over time as the packing burns in. So I will put a few thousand miles on it and report back later. But so far I'm very impressed. I held it up to the daylight and you could look right through it..so the performance and flow is obviously much better than stock, but the noise is not annoying. I'm digging this.
:hippie:
Have you changed anything other than the muffler? Drone usually has more to do with the length and placement of the muffler and termination style. Sound clips?
Any updates on the muffler's performance? I'm just wondering if you've run into the rattling issue some have had with this muffler. I think I may fork out the dough for the VT depending on your review.
I was going to get the VT, but I read some reviews about the rattle, and also they do not have a drop in configuration for our 4runners, center in offset out in a 2.5" size. I wanted to do it myself and wouldnt be into rerouting anything or doing a larger diam.
I just got a Gibson Cat Back. Supposed to be a perfect drop-in fit, similar performance, low drone but good sound. I am installing this weekend, Ill have to post once its on about how easy the install was but it is another option if you are open to spending a little bit more.
I have rattling but haven't totally confirmed what it is. It only happens sometimes...and it never happens unless I'm sitting still with the vehicle in gear and foot on the brake. So it's not a big deal to me at all.
Elchele89
