E brake light
The light comes on for 3 reasons:
- E brake is engaged (switch is at the back of the rod that moves when you pull the lever, under the dash.
- Brake fluid is low (switch is a float in the reservoir under the hood, it does sometimes stick)
- If the battery and brake lights come on together, you have a bad alternator.
What does the switch look like it and what may you have to do to it
The e-brake switch is mounted at the end of the rod that moves when you pull the lever, under the dash, just like Dingman said. If it is sticking in the On position when you release the brake, you have to unstick it or replace it.
The brake fluid level switch is part of the brake master cylinder cover.
Your quest should be to find out what problem is causing the light to be on, not how to turn it off.
Find the problem, and you will solve your symptom.
