ABS is disabled when in 4LO so that's not interfering with your e-locker engagement. Your differential doesn't care if the axle shaft goes back into the exact same splines. If you have the rear axle off the ground and spin one side of the axle and the other side spins the opposite direction then your axle shaft is engaged to the differential. (Assuming you are in park and 2wd.) You most likely have an internal problem with the elocker actuator. There's a couple threads about it including a "rebuild/service" thread on the elocker actuator on here if you search around.Jacked up the truck, 4low in neutral, press lock and nothing happens except the blinking light; can't hear or feel the motor trying.
On to the threads with electrical trouble shooting assuming the abs wheel sensor wouldn't have anything to do with it as that's that only electrical touched during wheel bearings.
No check engine lights or other issues.
