E-locker w/4.30 gears complete housing and front differential
justinh
Matching diff set out of 1999 Highlander, rear housing and 3rd member with e-locker included (no shafts). Front differential included with set.
Rear 3rd got new gears from ECGS a few years ago and has about 30k miles on it.
$700. Located in Canton, GA will not separate.
E-locker controller, harness and switch also available for $150.
Matching diff set out of 1999 Highlander, rear housing and 3rd member with e-locker included. Front differential included with set.
I've received a lot of PM's and interest about splitting them up. If there are people that want individual components and I can sell it all then I am open to that, but we need to find people to take the front and rear at the same time.
If you were to sell the from and rear separately, how much would you sell the entire front 3rd member for? I already bought an e-locked rear end locally and just need the 4.30's up from to match the rear. Also, what would shipping run to send to 95610? Thanks
$250 for the front and $500 for the rear (including housing). If we can find buyers for both.
Will that come with the actuator? How many miles on the frnt gears?
The front actuator? Or are you asking about the e-locker motor for the rear?
I can ship the add actuator and tube for the front but it will add to the shipping cost since it adds so much size. I'd recommend reusing your own unless yours is bad.
I wasn't sure what all it was coming with because the dismantlers around my area were asking me if I wanted the third member with the actuator or if I just needed the third member only for the front. Make sense? Sorry, I've never done a did swap so in going off what I've read and heard.
Justin,
I have a buddy in outside of Columbia SC that had expressed interest in a locking rear some time ago but need to touch base with him again tomorrow if they still are available.
As long as your actuator is good it doesn't make much sense to ship it because of the size it adds.
back to the top....didn't think it would be this hard to get rid of a matched set with the entire rear housing. Bolt in and go!
Do you want the housing and everything or just the 3rd?
I'd split it if we can find people that want both parts.
I only need the 3rd. Im affraid shipping with the housing would be really espensive. I've seen people ship 3rds in 5 gallon buckets from home depot with the lid screwed on. The housing would need to be strapped to a pallet.
Yeah, do you really have an 03? If so the housing wouldn't work anyway.
I've shipped them in 5 gallon buckets before. Never an e-locker though, i'm thinking the actuator would have to come off for it to fit.
Yes I have an 03 so I was just going to modify my stock housing to accept the elocker.
I don't think I could go low enough to make it worth your while since this is geared 4.30 you'd have to regear this differential to get a ratio that is available for your front end too. You are probably best off getting a 4.10 ratio since you could use the OEM front diff from a 4cyl 2005+ Tacoma in your 4runner.
