Was the E-locker an option on the 97 4runner? I have a 97 SR5 and don't have the switch for it in mine. Anyone know how much it'd be for a dealer to install it?
Sorry to thread jack but while on this topic,
does anyone have a complete list of cars and years that the rear axle comes with an elocker and would fit in our cars?
Only 3rd gen 4runners will have an axle that will just bolt straight up.
I would of thought at least the tacomas rear axle was similar
The Tacoma axle has leaf springs instead of coils and control arms. The mounts are totally different so even though the diff is the same on the TRD off road Tacos, the axle won't work without heavy modification. It's much easier to just put a Taco elocker diff in your axle even though that requires some modification to the housing.
Swapping a complete 4runner elocked axle is the easiest, but there's still a problem. The vast majority of elocked 4runners are 4.30 gears and the vast majority of non-elocked 4runners are 4.10 gears. So, most likely you have 4.10s and it will be difficult to find an elocked 4runner axle that matches the gear ratio. That leaves you with 3 choices if all you can find is a 4.30 elocked 4runner axle:
1) Regear the front diff to 4.30
2) Swap front diffs with a 4.30 diff
3) Put your 4.10s in the new elocked axle (swap ring and pinions) and leave the front alone.
Most elocked Tacos are 4.10s, so if you can get one of those, you can retrofit it into your housing (but like mentioned earlier, it still requires some cutting and welding on your axle housing to make it fit).
*Keep in mind...
You first need to find out what gear ratio you have now. Most likely it's 4.10, but not for sure. To find out, block the tires and put it in "N". Then jack up one rear tire. Make a mark on the tire and the driveshaft. Have a buddy spin the tire slowly exactly 20 times while you count the driveshaft revolutions. 41 revos = 4.10s, 39 = 3.90s, 43 = 4.30s, etc...
yes, it was available in '97. I know this because I have a '97 elocker axle in my '99.
I don't know if the stealership still deals in elockers for the 3rd gens anymore but if they did it would cost you A LOT of money. You're best bet is to find you a complete rear axle with elocker and just completely swap axles. If, and only if, you are mechanic friendly and know what you're doing there is an elocker retrofit to fit the elocker 3rd in the factory 3rd's place of your current axle. It is a lot of very detailed and precise work though but would be cheaper because you are buying just the 3rd instead of the complete axle. I suggest doing some reading up on it.
THIS ought to help you.
Great help, would regearing the front cost more then just getting a 4.30 diff in the front? Also are the e-locked 4runnners fronts 4.30? I assume so
I think it would just be easier to buy a 4.10 E-Locker from Toyota.
CARRIER ASSEMBLY, DIFFERENTIAL, REAR. Rear axle housing & differential; Rear axle housing & differential for 1999 TOYOTA 4RUNNER (411103D030)
another thread rez, you find all the good 2011 threads dude. =}
At least I'm doing my research instead of starting new ones.![]()
