Early 5th gen (10-13) baja fog help
tristero
I'm having an issue with the baja fog install with the harnesses they sent. I think the female connector is too long. For those with the 2010-2013 that did this can you help out with your install? I can only find 2014+ installs documented.
Pics for reference:
1 OEM
2. Baja harness female end
3. About as far as I can force the baja harness in—about 1/8" too short to finish the connection
interesting...I was told its "plug and play" and I am attempting to install these this weekend too
Could you please post up some pics of the harness you received? I've been emailing them since Sunday and this still isn't resolved unfortunately.
Looks similar to the one you have
Thanks! Looks like yours has a female end that's a bit shorter at the top, maybe 1-2mm and has legs on each side.
Please let me know if these fit for you. I'm still working with [MENTION=87816]Baja Designs[/MENTION] to get this resolved.
Pics for reference:
1 OEM
I think you guys sent me the wrong harness...
Sorry about this! It's possible we accidentally sent the incorrect connectors. A few of the Toyota connectors are almost identical except the pin spacing is slightly different.
We'll happily get you the correct connectors. Please reach out if you haven't already. [email protected]
Baja Designs
Offroad LED, Dual Sports Kits, LED & HID Lighting | Baja Designs
