East Coast Gear Supply = 7.5" Clamshell Bushing
binqker
Received my order yesterday and test fitted the bushing. I'm a bit bugged out the fact that it has a little bit of play. I called ECGS tech support questioning my concerns about the play. The guy said it is normal to have the play. Anyone here running it and have any issues? Let me know how your bushing is holding up to?
Thanks,
John
Thanks,
John
mine went in perfect and snug, had to tap it in. only have a couple hundred miles on mine so... can't answer to the long run. I also put mine in the freezer so it would go in easier.
you might want to take a look [MENTION=120071]mtbtim[/MENTION] vid?
YouTube
I'm not sure if your asking about install or with CV in?
this is where they test the CV connection
YouTube
Yes, it is a bit hard to decipher exactly what OP is saying.
I found the ECGS bushing to be quite tough to drive in. For sure a firm fit in the clamshell. The CV went back in with no issues and nearly 0 movement once reassembled. I've got 7,000 km on it now and still nearly 0 movement on the CV.
Hope this helps OP.
YouTube
YouTube
Thanks for the Vid. No I was not asking for the video.
Hope this helps OP.
I installed it yesterday and went in smoothly. Yea zero play when it is installed. :)
Thanks,
John
So which is it? Where are you testing for play at?
charlesz
