eBay find: 4runner specific Hella micro DE fog light kit, new in box
BrianK14
Me=1, discontinued parts =0. I lucked into finding a new, still in the box, Hella micro DE foglight kit for my rig. I had been looking at options to add fogs to my SR5. To my knowledge, these kits were discontinued 3-4 years ago. New from Toyota stock fogs are prohibitively expensive. Used from EBay are usually rusted, pitted, cracked, etc. So, I had planned to order The Depo aftermarket fogs and brackets from Amazon. Then, I found this kit. Good price, brand new. Even including the installation instructions.
Fogs, brackets, relay and switch are all included. That makes the kit a lot cheaper than even the Depo Amazon fogs. Although I have a stock headlight stalk switch w/ fog controls on the way, so I won't be using the included switch. Actually, I have a second headlight stalk on the way. I learned that the Solara stalk that I found first, which is recommended, easier to find and cheaper, will not work on 01-02 models 4runners. Doesn't fit. Should work on earlier model years. Here's the Solara switch that won't fit. If anyone needs a head light stalk switch w/ fog controls for earlier model 4runner's, this ones for sale:
Now for the bad news. Rust=1, me=0. The bolts/nuts under the front bumper that the brackets mount to are rusted beyond usefulness. So, that turned into pulling the bumper. See the bolts where the brackets mount? Yeah, me either. That's because they're mostly gone. Lots of new bolts/nuts/clips, a few mount brackets, and one bumper reinforcement later, and the cost of this project has doubled. But, the front section of the truck will be rust free.
Went at the parts I won't be replacing with the grinder.
Before:
After:
Once it dry and warm enough, it'll get some Rustoleum rust converter, followed by Eastwood satin chassis black. So, that's where we stand now. Waiting for parts from Toyota and some warm dry weather for painting.
Not sure. He doesn't have any more kits listed currently. It may be worth checking with him though. His Ebay username is "johnsatozstuff". Quick shipping and as described parts.
Nice, I wasn't even aware to look for such a thing. I'll have to keep my eyes open.
My Limited was in a front end collision before I got it and they patched it up but didn't go the extra mile, or even an extra millimeter in repairing it, thus just left the fog lights off. So I have everything for fogs, the stalk switch, the wiring is there dangling ready to plug in, but no lights.
Time for a progress update. Rustoleum rust converter for the frame:
Then Eastwood chassis paint:
Also cleaned up the back of the bumper and hit it with rust converter. Should lead to several more years of life for the bumper:
Several members have reported water intrusion issues with the MicroDE's. Various fixes have been tried, including a shield produced by Hella. I don't have that, so I used a combination of other fixes from the forum. Extended the breather tube, silicone grease to help seal the rubber caps, followed by zip tie'ing the caps on:
I was surprised that the factory harness plugs weren't in too bad a shape after hanging under the rig open to the elements for 15 years:
Cleaned them up a bit:
Installed the relay and the correct headlight stalk switch, and plugged in the lights:
We have light. Now just waiting on the hardware to reassemble and hang the bumper back on. Should be here sometime this week..
In relation to this thread,
I have a 97 Sr5, without the fog lights.
Is my truck at all prewired for fogs?
I ask because my old Nissan Sentra, eventhough it was not equiped with the fogs did have the wiring already.
Thanks!
Thanks!
I believe that all 99+ models are pre-wired, and all 98 or older are not. Not 100% sure on that though
Been debating on getting those for my T4R, I didn't know they came from Toyota, I thought I would have to fab some brackets. After once last attempt to stop my axle seals from puking grease, I will have to get a set.
Got this project wrapped up last weekend. Assembled the bumper with fog lights and new hardware.
And put the bumper back on the truck.
You can't tell from these pics, but light output is very nice. Really helps out the poor performing stock headlights.
Nice find. I had to use parts off 2 additional pairs of OEM Toyota foglights to make my original ones operational again, the hardware was seized and broke off or stripped trying to remove them and the housings themselves were seized to the brackets so I couldn't adjust them.
The MicroDE fogs with the vertical adjustment plates are readily available for around $60 each, someone should reproduce the 4Runner-specific brackets. Good idea with the vent hoses, one of my MicroDE's was ruined due to water getting into it.
I have them, they fit and plug right in. Haven't had any issues with them ever, only thing I can think of is that I can't rotate the beam, but I don't know if the hella's can be rotated either.
Can't rotate the Hellas or OEM fogs either. Is the foglight cutoff not level?
The universal kits are still available,but the 4Rrunner-specific kit with the direct bolt-on brackets and OEM style electrical connectors were discontinued
gottcha, I guess you could buy the Depo kit off Amazon & upgrade the lighting to Hella.
REE
