Just make sure it is from a vehicle with no immobilizer...
-Charlie
I have yet to come across an ecu in a Toyota bad. Granted, it's possible. I would suspect it last..
The 3rd gen solenoid going bad or stuck. Very likely.. :]
Sent from my SM-A536V using Tapatalk
Disregard what i asked about replacing the solenoid*
Tim does? thanks for the reply. I'll look for it. These are the part numbers i was given. Apparently there's more than one.
85420-21090 qty 2
35250-50030 qty1
That's right there are three. Are you planning on doing this yourself or the mechanic? Either way I would recommend changing all three of the solenoids the filter and a new gasket at the same time. I'm sure you can actually buy all those as a whole kit. If you do it yourself the only ***** is getting all the old gasket maker off if the mechanic used that. Get a gasket instead of that gasket maker. It will make your life much easier if you need to pull the pan again. Scraping that shit off takes longer than the the rest of the job.
I'm going to do this... I wont be doing this myself. I need to rely on the dealer... it's been a dealer maintained truck since i drove it off the lot for the first time.
All,
After getting prices for my solenoids i asked what the charge would be to install them. I was informed that they don't do transmission work. They said something about if the parts were replaced(solenoids) "pressures" would change and that could damage my Transmission and if that happened then they would have to deal with that..
This sound normal to anyone?
