I installed a URD supercharger kit with 7th injector piggyback ECU for a v6 '97.
The ECU is not giving a ground for the fuel pump relay. I've checked all fuses and made sure that there was continuity between the relay and ECU. The ECU is getting power as well. The relay is getting before switch power and coil power. It just isn't grounding from the ECU.
I've double checked my piggy back wiring and all work was done with the battery disconnected and the plugs disconnected from the ECU.
I'm pretty stumped at this point.
