EGR Temp Sensor Diagnostics
Buck Bridges
Hey wonderful people...
First of all, thank you to all the folks who share their time and experience to help us keep the 4runners on the road. I bought my 1995 3.0 2WD (150k miles) a couple of months ago and this forum has really been an awesome resource. Again, thank you all!!
Ok, here is the rundown. Bought the truck and suspected it had a burnt valve as the compression test showed 50psi in Cylinder 1. There was a bit of an oil leak coming from the valve cover so pulled off the head to check the valve and replace the valve cover gaskets. Valves were fine and did a bit more snooping around and then I found it... A RAT had made its home in the engine compartment and it had chewed through the fuel injection wires! That was a quick fix, and problem solved. Compression was back to normal and all is good...
Drive about 50 miles and the CEL comes on. I had noticed it was a bit sluggish but I just assumed thats the way it drives. Code 71, "EGR System Malfunction" and then I do a few things to check my system,
1) Checked the EGR Valve and did the vacuum test and the engine stalled like it should. EGR Valve is working properly.
2) Took apart the Vacuum Modulator and cleaned the filter. No problems
3) Checked all the hoses for cracks and leaks but everything looks good.
4) Double checked the vacuum hose diagram to make sure all the hoses are connected properly. Since I took off the head, it is very possible that I didn't connect it all correctly. To the best of my knowledge, everything seems to be in the right spot.
5) Took it in the shop! I read a post on this forum that said, "Hey, after you've done all you can do, stop wasting the time and money and get a professional to look at it!" I took that advice.
They said my EGR Temperature Sensor was the culprit and quoted me $300 for the new sensor. WHAT?!? I found one online for $140 but I haven't ordered it yet because I am still not convinced that is the source of the problem. Pictures are attached.
My questions...
1) Is there any way to test the temp sensor to verify that is the cause of the problem? I can't find much in the manual.
2) If you look at the picture closely, you can see a little bit of damage to the sensor wires. It is reasonable to think that is whats causing the malfunction?
3) The temp sensor is connected to two wires, one green and one brown/reddish. Does it matter how they are connected to the temp sensor? Meaning should green be on the left plug or vice versa?
4) Are the green and brown/reddish wires grounded correctly? In the picture, you can see that the copper wire is actually not connected very well. Would you suspect that might be causing the temp sensor error?
Thank you for taking the time to share your thoughts. If the solution is to buy a new EGR temp sensor than that's what I'll do but I want to find a way to determine if that is the actual cause of the problem. Any and all suggestions are greatly welcomed!
You might want to try the classic t4r section, your 95 is 2nd gen. You can use a resistor in place of the egr temp sensor and fool the computer. I cant remember the resistance but search and I'm sure you'll find it.
good luck
